1994 JDM GSR ENGINE SWAP w/ LSD $3000.00
Old Nov 29, 2004 | 05:59 PM
myhatchrips's Avatar
Default 1994 JDM GSR ENGINE SWAP w/ LSD MANY EXTRAS!!
This is a complete engine swap. It will directly fit into any 1992-1995 Honda Civic chassis. It will also fit into any 1994-2001 Acura Integra chassis. I can honestly say that this engine is in immaculate condition. Both performance and appearance wise. With only 40,000 miles you cannot go wrong! This weekend I did a compression test and all four cylinders put out 220 PSI. I performed oil changes every 2,500 miles along with a complete tune-up 5,000 miles ago. Runs perfect and idles very smooth. It has a really nice powerband throughout the entire rpm band. The engine has been dynoed at puts out 186 whp (wheel-horsepower) and 131 wtq (wheel-torque). That means it pushes out approximately 220 horsepower to the flywheel which is plenty of power for a daily driven vehicle. Comes complete with Engine, Transmission, Ecu, Axles, Engine Mounts, Shift Linkage, JG Adjustable Cam Gears, Skunk 2 Intake Manifold, JDM 2.5 Inch Header, 3 Inch Integra Type-R Cold Air Intake, 64 mm Maxbore.com Ported Throttle Body, B&M Fuel Pressure Regulator, Hyperclutch Street Disc setup. You will not need anything else to install this engine if you drop it into any of the two chassis's that I've listed above. Im firm on the price so please do not try and offer me anything lower. My asking price is $3000.00 firm. Serious inquires only. If you're interested drop me an e-mail at "lovemahbootl@yahoo.com" and I will reply to you promptly. Thank You.
Old Nov 29, 2004 | 06:10 PM
Kyles ej1's Avatar
Default Re: 1994 JDM GSR ENGINE SWAP w/ LSD MANY EXTRAS!! (myhatchrips)
**** i wish i had a job or $, id buy it in a heartbeat.
Old Nov 29, 2004 | 07:39 PM
AnDThEnWuT's Avatar
would the motor pass smog?
Old Nov 29, 2004 | 08:12 PM
Default Re: 1994 JDM GSR ENGINE SWAP w/ LSD MANY EXTRAS!! (AnDThEnWuT)
yes it will pass smog.
Old Dec 15, 2004 | 09:43 PM
prestonpark's Avatar
some one buy this motor
bumo for a clean *** motor
nucar4me
Mar 5, 2011 07:59 AM
myhatchrips
Oct 20, 2004 01:10 PM
myhatchrips
Aug 8, 2004 10:10 PM
