Finally fixed my vtec problem
Old Nov 29, 2004 | 04:08 PM
96tegsr's Avatar
Default Finally fixed my vtec problem
well my car did not have vtec for about a year now. It was trowing code 22. I fixed the problem by putting an outside oil line. well it sorta fix the problem. Now im getting vtec only if the fields vtec controller is on but it cuts off the fuel at 6500 rpm and it STILL trowing the code 22 and 17. Well i was thinking of just taking the fields out to solve the problem? atleast i have vtec now. ny advice or similar situation that u guys came accross with?
Old Nov 29, 2004 | 08:59 PM
96tegsr's Avatar
Default Re: Finally fixed my vtec problem (96tegsr)
ttt
Old Nov 29, 2004 | 09:46 PM
jdmcivicferio's Avatar
well code 22 is oil pressure and code 17 is vehicle speed sensor, so fix both codes and vtec will work again
Old Nov 29, 2004 | 10:02 PM
96tegsr's Avatar
Default Re: Finally fixed my vtec problem (jdmcivicferio)
any idea how? see i didnt have the code 17 before, it just came off today after we installed the outside oil line. and for the code 22, i have no clue how to fix that. wiring is good, vtec oil pressure switch and vtec selenoid is good. btw, if anyone wants my fields vtec controller, all u gotta do is uninstall it from my car and its YOURS!.
Old Nov 30, 2004 | 07:07 AM
MAV3RiCK478's Avatar
check the oil pressure sending unit on the back of the block next to your oil filter. it looks like a hersey kiss.
are you serious about the fields controller, i might be interested.
cleanazcoupe
Jun 30, 2009 10:28 AM
Brandoff
Sep 1, 2008 03:15 PM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
2trix
Apr 2, 2004 08:15 PM
Hondasaurs
May 9, 2003 08:51 PM
