replacing msd blaster coil 2 with stock external coil?
I was wondering if i can just replace the stock external coil with the msd blaster coil be putting the 2 wires on it. I wanted to try it to see if my stock coil is bad. but the ? is that will the msd coil plug right on??
So connect yellow and yellow/blk wire together can put on the + coil and then negetive green on coil? I can still run it with stock spark wires right? thanks man i gotta try this out and see if the stock coil is out.
You can test the stock coil to see if it's bad.
IMO, you're wasting your money on that coil.
Good luck though.
BTW, I wouldn't hack your stock connector if I was you.
Make sure you solder your connections if you decide
to use that msd coil.
Good luck though.
951dc5
Jun 9, 2005 06:51 PM
