ARP Head Bolts on USDM d15b7
Old Nov 29, 2004 | 02:47 PM
.BigSexy's Avatar
most hood white kid
Default ARP Head Bolts on USDM d15b7
i have only found ones for a d16z6..willthese work on my USDM b7?? also...are all the studs the same length...if not...where do the short one(s) go? Thanks. and I did search
Old Nov 29, 2004 | 03:00 PM
.BigSexy's Avatar
most hood white kid
bump!
Old Nov 29, 2004 | 03:40 PM
Br1anPham's Avatar
Default Re: (egcoupe94)
Yes, arp head studs from a z6 will fit a b7.
You boostin' or wha? Have fun.
Old Nov 29, 2004 | 03:41 PM
lohatch's Avatar
Default Re: ARP Head Bolts on USDM d15b7 (egcoupe94)
yep use the Z6 headstuds on the B7. they also work for the A6.
Old Nov 29, 2004 | 03:43 PM
Br1anPham's Avatar
Default Re: ARP Head Bolts on USDM d15b7 (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">yep use the Z6 headstuds on the B7. they also work for the A6.</TD></TR></TABLE>
Absolutely correct. Now try using them on a d16y-series and that's when you have problems.
AND all of them are the same size and length. In the head it seems that there should be longer/shorter studs but the depth of how far the stud goes in accommodates for it. When you install it, you will know what I mean.
Old Nov 29, 2004 | 06:18 PM
.BigSexy's Avatar
most hood white kid
well I am building a boosted z6...but on my b7...i think my head bolts may have stretched, and they are freaking 80 bucks from honda...so i will spend 90 on ARP head studs...thanks guys!
marcsed6
Jan 3, 2010 12:34 PM
flashedDc5
Oct 23, 2006 06:46 PM
Jester88Si
Apr 19, 2005 11:53 AM
JonnyCoupe
Mar 10, 2005 07:55 AM
.BigSexy
Oct 15, 2004 09:12 PM
