Replacing axel on a 88 CRX SI w/ a zc motor
Old Dec 30, 2001 | 05:20 PM
eddievelasco's Avatar
Default Replacing axel on a 88 CRX SI w/ a zc motor
I neen help on replacing a pass side axel on a 88 crx si w/ a zc motor. I need help. thanks
Old Dec 30, 2001 | 06:23 PM
SiREF8's Avatar
Default Re: Replacing axel on a 88 CRX SI w/ a zc motor (eddievelasco)
What tranny are you using w/the zc in your car?
Old Dec 30, 2001 | 06:46 PM
DragII's Avatar
25 Year Member
Default Re: Replacing axel on a 88 CRX SI w/ a zc motor (SiREF8)
what is the problem that you are having?
Old Dec 30, 2001 | 08:45 PM
Default Re: Replacing axel on a 88 CRX SI w/ a zc motor (DragII)
inner and outer cv boots are torn. need to replace axel. i need to know how to get the axel off the tranny.
Old Dec 31, 2001 | 08:36 AM
DragII's Avatar
25 Year Member
you just pry it out w/ a pry/crow bar.....you have to pull the end out of the hub first...you know how to swing the hub assembly out right?
Old Dec 31, 2001 | 09:37 AM
rainforest's Avatar
yep thats all it is . bolts and prying.
h22_crx
Oct 18, 2005 05:59 PM
kevo2k6
Jan 14, 2005 09:23 PM
88 Si
Jun 14, 2004 04:17 PM
wtfang
Apr 22, 2004 02:43 AM
IraceAcrx
Mar 4, 2004 06:03 PM
