a couple pre-winter pics
I hate lawn pics. Paint your car John Deere green and put a lawn deck on it if you want to go up on the grass. Other than that looks like a good motor setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lostcb7 »</TD></TR><TR><TD CLASS="quote">clean 4 door
are those 17s(i could be wrong)? 16s would make it look better....but its nice
</TD></TR></TABLE>are those 17s(i could be wrong)? 16s would make it look better....but its nice
yeah those are 17's. here is a pic of the 16" Kosie Racing Seneca's that are going on in the spring. probably going to paint them black of dark grey.
here are some specs
D16Y7 sohc non-vtec, bored .030 over, decked, blueprinted and balanced, custom Wiseco pistons (high-temp coated), Eagle H beam rods, ARP head studs and rod bolts, Balanced, polished knife-edged crank, Cometic head gasket, stock cylinder head, 3” turbo back exhaust, Apex’I N1 muffler, AX53 B60 P18 ball bearing turbo kit, GT front mount intercooler, blow off valve, and turbo timer, Exedy 3 puck clutch, AEM EMS, Accell 720cc injectors, AEM fuel rail, Aeromotive fuel pressure regulator, Walbro 255lph fuel pump, Turbo XS manual boost controller, NGK plugs
the car is winterized now boost is turned down, put some eibach sportlines on with 14" steelies and some 185's to cut through the snow. i'll get some snow pics soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcT »</TD></TR><TR><TD CLASS="quote">yeah those are 17's. here is a pic of the 16" Kosie Racing Seneca's that are going on in the spring. probably going to paint them black of dark grey.
the kosei's are def 106968674674376 times better
