stock 88' crx hf front sway bar size?
ok, i got the ES hyperflex bushing kit for my 88 crx hf. im adding a ST rear sway bar and keeping the stock front sway bar. my ES kit came with the endlinks for the front sway bar but did not come with the frame bushings. for ES sway bar frame bushings they give an option for 16mm,18mm, and 19mm. which one is the hf swaybar?
ok thanks. so should i order the 16mm bushings or the 18mm bushings? i just took off the bushing of the sway bar and i put a 16mm wrench up to the hole of the bushing and it matched up perfectly. i think i need to get the 16mm's.
