VTEC distributor question, cap and rotor interchangeable
Old Nov 29, 2004 | 12:10 PM
Dan GSR's Avatar
Default VTEC distributor question, cap and rotor interchangeable
I have a GSR head
From my understanding any B seires VTEC distributor will fit
I have a OBD I distributor from a B16A
Which cap and rotor should I use need?
95 Del Sol VTEC ?
95 GSR?
00 ITR?
00 GSR?
This will be going on hybrid all motor engine.
Old Nov 29, 2004 | 07:16 PM
mmuller's Avatar
Mad Scientist
Default Re: VTEC distributor question, cap and rotor interchangeable (Dan GSR)
get a cap for a del sol vtec or 99 si.
the gsr dizzy case is a little different than the rest and caps dont interchange
Old Nov 29, 2004 | 07:37 PM
Dan GSR's Avatar
Default Re: VTEC distributor question, cap and rotor interchangeable (mmuller)
good to know
I didn't know that
Old Nov 29, 2004 | 07:46 PM
Dan GSR's Avatar
I just cross referenced all the parts
Looks like the LS and Si share the same cap and rotor
GSR and ITR share the same cap and rotor
Old Nov 29, 2004 | 08:36 PM
racinategra's Avatar
Ls VtEc with b16 head and pr3 ecu. what distributor should i run???? currently running LS.
Old Nov 29, 2004 | 08:54 PM
Dan GSR's Avatar
Default Re: (racinategra)
any B series VTEC distributor will work
what car is this in?
Old Nov 30, 2004 | 02:22 PM
91 integra (DA) BUMP for LS VTEC
Old Nov 30, 2004 | 02:50 PM
Dan GSR's Avatar
thats an obd 0 car, did you convert to OBD I ?
Old Nov 30, 2004 | 06:00 PM
negatory
Old Nov 30, 2004 | 06:29 PM
mmuller's Avatar
Mad Scientist
you could cut one of the legs off your ls dizzy and use it; or you need a obd0 b16 dizzy.
Old Dec 1, 2004 | 10:01 AM
thanks to everybody, im running ls right now but am getting that cel code concerning the distributor
Old Jan 25, 2005 | 11:54 PM
92 civic VX B18c's Avatar
HT Black Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">get a cap for a del sol vtec or 99 si.
the gsr dizzy case is a little different than the rest and caps dont interchange</TD></TR></TABLE>hmm that would explain what's going on with my cap....I thought I had a 94 GSR distributor, and I bought a replacement cap and rotor for a 94 gsr, and when i went to install it I found out my new cap is much larger then my old cap, and will not fit
Rigginit
Dec 26, 2009 09:57 PM
JAYDmManny1331
Sep 18, 2009 08:01 AM
jdmdohcek98
Oct 13, 2008 09:56 AM
D-rush08
Sep 7, 2006 10:08 AM
91hatch_on17's
Jun 25, 2003 10:26 PM
