inch pounds vs foot pounds ????
Old Nov 29, 2004 | 11:55 AM
boosted350z's Avatar
Default inch pounds vs foot pounds ????
i just reinstalled my flywheel and ended up torquing the fugging bolts to 76 "INCH" pounds instead of the correct 76 "FOOT" pounds, yet , when i double checked the torque afterwards with my Foot pound torque wrench, they were all tightened to at least 76 FOOT pounds. i don't get it.
isnt FOOT pounds alot more torque than inch pounds ???
wtf ???
Old Nov 29, 2004 | 12:01 PM
mdpalmer's Avatar
Default Re: inch pounds vs foot pounds ???? (boosted350z)
A foot-pound is twelve times bigger than an inch-pound, as there are 12 inches in a foot (so 1 ft-lb = 12 in-lb).
Old Nov 29, 2004 | 12:56 PM
Default Re: inch pounds vs foot pounds ???? (mdpalmer)
thats what i thought. But i tightened my flywheel bolts to 76 "INCH" pounds, yet when i checked them with my "foot" pound torque wrench, all the bolts were already at 76 "foot" pounds.
how the **** could that be ?
Old Nov 29, 2004 | 01:54 PM
pip9's Avatar
i think both ur torque wrenchs are ft/lbs. An inch pound torque wrench is much much smaller than most ft/lbs wrenchs. Either that or one of ur torque wrenchs is way off.
Old Nov 29, 2004 | 02:51 PM
SiRex91's Avatar
Default Re: inch pounds vs foot pounds ???? (pip9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote">i think both ur torque wrenchs are ft/lbs. An inch pound torque wrench is much much smaller than most ft/lbs wrenchs. Either that or one of ur torque wrenchs is way off.</TD></TR></TABLE>
I would get both of your torque wrenches recalibrated. Don't want those flywheel bolts coming loose.
Old Nov 30, 2004 | 10:32 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted350z &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought. But i tightened my flywheel bolts to 76 "INCH" pounds, yet when i checked them with my "foot" pound torque wrench, all the bolts were already at 76 "foot" pounds.
I'd say you're using 2 torque wrenches and not realizing it. There's no way you could torque down a bolt to 76 INCH LBS. and then it not move when you re-torque it to 76 FOOT LBS. because 76 INCH LBS. equates to about 6 FOOT LBS. That is if the wrenches are both working properly.
timbo74
Apr 6, 2019 12:48 PM
killingtwobirds
Sep 11, 2008 11:13 AM
92integracer
Nov 16, 2006 08:51 PM
boosted350z
Nov 30, 2004 04:55 AM
B18Redline
Nov 28, 2004 06:52 PM
