can you weld aluminum to aluminized piping?
Old Nov 29, 2004 | 11:45 AM
AirWaveGT's Avatar
Default can you weld aluminum to aluminized piping?
i have an aluminum flange that i need welded onto aluminized piping. can it be done?
Old Nov 29, 2004 | 01:05 PM
phat51's Avatar
Default Re: can you weld aluminum to aluminized piping? (AirWaveGT)
No, aluminized piping is steel pipe with a coating on it to help prevent rusting
Old Nov 29, 2004 | 01:13 PM
rtype11's Avatar
if the flange fits over the pipe you may be able to flare it, but thats it, steel exhaust flanges are cheap.
Old Nov 29, 2004 | 03:42 PM
project dc2's Avatar
Default Re: can you weld aluminum to aluminized piping? (rtype11)
im pretty sure hes talkin about a blow off valve flange and no. aluminzed is jsut a coating . not the piping material itself
Old Nov 29, 2004 | 03:51 PM
SiRex91's Avatar
Default Re: can you weld aluminum to aluminized piping? (project dc2)
You can braze them together, but make sure both surfaces are prepped before joining the two pieces.
thegatekeeper14
Welding / Fabrication
18
Apr 19, 2011 07:50 PM
davechat7
Oct 25, 2007 03:40 PM
adseguy
Oct 4, 2004 04:07 PM
sung
Jun 22, 2003 09:57 PM
