bad gas smell from exhaust
when im idling, i smell gas.. i don't know what's causing the problem. leaks in the exhaust maybe? or bad cat? i don't know.
if anyone of you know what's really causing the problem, it will help me and help other people as well who has the same problem i have
thanks!
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l e o h j »</TD></TR><TR><TD CLASS="quote">when im idling, i smell gas.. i don't know what's causing the problem. leaks in the exhaust maybe? or bad cat? i don't know.
thanks!
Close your legs. Oh. From the exhaust? Check for fuel leaks by visually inspecting the engine bay fuel lines. There are not that many of them. You may also check your air intake for fuel and that may lead to you a faulty injector. Not uncommon.
Does the car run normally?
exhaust doesn't smell like gas!!!
unless you're running really rich which you'd notice a big change in your performance/mileage
thanks!
</TD></TR></TABLE>Close your legs. Oh. From the exhaust? Check for fuel leaks by visually inspecting the engine bay fuel lines. There are not that many of them. You may also check your air intake for fuel and that may lead to you a faulty injector. Not uncommon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YasRex »</TD></TR><TR><TD CLASS="quote">
unless you're running really rich which you'd notice a big change in your performance/mileage</TD></TR></TABLE>
patrickstar
11
Nov 8, 2008 10:05 PM
Integra4lyfe069
Aug 6, 2008 09:22 AM
Philip
19
Aug 9, 2003 06:47 PM
