is Heat sheild removal safe?
Old Nov 29, 2004 | 10:19 AM
JonathanRuiz's Avatar
Default is Heat sheild removal safe?
Ok i have some rattle noises coming from somewhere in the exhaust system. I have recieved a lot o notices that the problem is the cat heat sheild or the headers. I will buy headers and a new hi-flow cat, but is removing the cat heat sheild even safe?
Old Nov 29, 2004 | 10:32 AM
dfoxengr's Avatar
Default Re: is Heat sheild removal safe? (JonathanRuiz)
yes its fine
Old Nov 29, 2004 | 10:42 AM
94ls's Avatar
mine started to rust off and rattle like crazy... took all of em off! it's fine
Old Nov 29, 2004 | 11:58 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: is Heat sheild removal safe? (94ls)
Perfectly fine. Which heatshield are you speaking of removing? In any case, both are fine to remove.
The header shield is there just to reduce underhood temperatures. The catalytic converter one is there just for safety. Say you park over a bunch of dry leaves. You don't want them to catch fire or anything. But it's pretty damn rare that that would happen.
You'll be fine.
Old Nov 29, 2004 | 12:42 PM
RidinStock's Avatar
Default Re: is Heat sheild removal safe? (shamoo)
Yea I've had my heat shield off and the worst thing that happened to me is I picked up a plastic bag under there. It smelled like burnt plastic for a month.
I don't see why it wouldn't be safe though, it hasn't caused any concerning problems for me.
Old Nov 29, 2004 | 03:00 PM
orangebarius's Avatar
Default Re: is Heat sheild removal safe? (RidinStock)
i have absolutely no heat shields throughout my whole exhaust. i havent had a problem. some people say ur floor will get hot, well this is not true. just dont park on dead leaves or grass and youll be fine.
Old Nov 29, 2004 | 03:43 PM
LSvtec03's Avatar
Default Re: is Heat sheild removal safe? (orangebarius)
i never had any problems after taking mine off.
Old Nov 29, 2004 | 04:28 PM
PhatOptimo's Avatar
Default Re: is Heat sheild removal safe? (LSvtec03)
It keeps your hands away from the pipes. Basicly there to protect you from getting burned. I'm sure its save plenty of people. It won't hurt to remove be sure the car is cold and keep your hands away from the hot pipes
Old Nov 29, 2004 | 04:32 PM
shamoo's Avatar
Default Re: is Heat sheild removal safe? (PhatOptimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatOptimo &raquo;</TD></TR><TR><TD CLASS="quote">It keeps your hands away from the pipes. Basicly there to protect you from getting burned. I'm sure its save plenty of people. It won't hurt to remove be sure the car is cold and keep your hands away from the hot pipes </TD></TR></TABLE>
Well....I guess so. But the heatshield itself gets VERY hot. You wouldn't want to touch that either.
Vtecfool's Avatar
i suggest you don't remove it if you live in a area with high grass..etc, you might cause a fire! But if your in the city... go for it!
otgarza
Honda CR-V & Element
Dec 4, 2012 03:52 PM
DC4 Rasta
Feb 1, 2006 09:41 AM
B16CRX
Nov 12, 2002 05:52 PM
integranator
Nov 4, 2002 08:38 AM
Woody_geeser
Jun 28, 2001 11:37 AM
