Timing belt tensioner and spring replacement recommended ?
Old Nov 29, 2004 | 09:59 AM
alotawatts's Avatar
Default Timing belt tensioner and spring replacement recommended ?
When replacing the timing belt I understand the water pump should be replaced as well ......I've also heard the tensioner and spring ...true ?
Old Nov 29, 2004 | 10:42 AM
SOHCD16y8's Avatar
Yes, you dont need to do the water pump but why not its already apart and only cost like 30 bucks
Old Nov 29, 2004 | 10:46 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Timing belt tensioner and spring replacement recommended ? (alotawatts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts &raquo;</TD></TR><TR><TD CLASS="quote">When replacing the timing belt I understand the water pump should be replaced as well ......I've also heard the tensioner and spring ...true ?</TD></TR></TABLE>
yes, it is a very good idea to swap the pump and tensioner while you are in there. cheap insurance. personally, i never swapped a spring, as ususally they do not go bad. couldn;t hurt i guess, and the spring i would imagine is not very much.
Old Nov 29, 2004 | 11:30 AM
snatch's Avatar
Default Re: Timing belt tensioner and spring replacement recommended ? (rodney)
I just replaced my T.B. and water pump. I would definitely do the water pump, and I wouldn't worry about the tensioner and spring. I didn't do it and it doesn't always seem common to replace it.
mikeintegra93
Jan 10, 2009 02:28 PM
4thgenx42
Mar 29, 2007 11:42 AM
OH_1fstgsr
Mar 7, 2007 10:13 AM
Ritchie
Feb 5, 2007 08:06 PM
nixadm
Aug 23, 2004 02:36 PM
