timing belt help fast
aight here we go i just installed the crank fine im my b18 then when we do the timing part the belt seems like its never tight enough. everytime we tighten the crank bolt the belt slips. and we got a new belt same thing. Need help bad.
you loosen the tensioner bolt. put the Tbelt on. have the crank pulley and the cam gears at TDC. put a socket on the crank pulley bolt and rotate couterclockwise 3 teeth on the cam gears. tighten the tensioner bolt.
Afflicted1
Aug 3, 2013 09:51 PM
