which tranny do i have...no serial number
Old Nov 29, 2004 | 08:54 AM
japrex's Avatar
Default which tranny do i have...no serial number
ok, i have a b16a1 swap with the cable tranny and a PR3 ecu but i dont know if it's the J1,S1, or Y1 tranny. i know that it is open differential because of the bar going through the differential. i dont have the serial number sticker on it. what other ways could i find out what it is? i have a few stamped numbers and such on it but i dont know which ones to look at. im wanting to know because if im correct the, if it's the Y1 then i can put an LSD in it later on right? thanks.
Old Nov 29, 2004 | 08:56 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
If you're in VTEC at 85mph in 5th, then you've got the J1 or S1. My B16A is shelved for now, so I can't tell you the low-range Revs, but I'm sure that someone else can help you without you having to break the law.
Old Nov 29, 2004 | 08:58 AM
japrex's Avatar
well see that is my problem also. mine is not in the car right now but i will be putting it in soon. so im not sure when vtec engages and what not.
Old Nov 29, 2004 | 09:01 AM
Default Re: (japrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japrex &raquo;</TD></TR><TR><TD CLASS="quote">well see that is my problem also. mine is not in the car right now but i will be putting it in soon. so im not sure when vtec engages and what not. </TD></TR></TABLE>
Well, it's not going to hurt your engine not knowing the tranny. If the swap came together, just tell us the head type... PR3, or PWO. If it's PR3, then it's either the J1, or S1... PWO, and it's a Y1. If you don't have axles, it's imperative that you learn the tranny, or just go out and buy a teg intermediate shaft.
Old Nov 29, 2004 | 09:16 AM
japrex's Avatar
yeah it's the PR3 head. and axles came with the swap so i do have axles for it. just wondering because i was hoping it was a Y1 so i could put an LSD in it later on.
Old Nov 29, 2004 | 09:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japrex &raquo;</TD></TR><TR><TD CLASS="quote">yeah it's the PR3 head. and axles came with the swap so i do have axles for it. just wondering because i was hoping it was a Y1 so i could put an LSD in it later on.</TD></TR></TABLE>
You can just as easily fit an LSD to a J1 or S1... mwahahahaha...
Old Nov 29, 2004 | 09:22 AM
japrex's Avatar
seriously? can it really be done? like if i were to get an lsd from an integra type R tranny?
JDAMC
Nov 26, 2006 08:07 AM
Goinfasterthanu
Aug 11, 2004 05:59 PM
MOTOCOMPO
18
May 27, 2004 01:16 PM
BseriesHatch
Nov 12, 2003 12:21 PM
