Stock Spring Rates?
Old Dec 30, 2001 | 03:30 PM
Flux's Avatar
Default Stock Spring Rates?
Can't find this anywhere, and I can't remember..
What are the stock spring rates on the ITR?
Old Dec 30, 2001 | 03:35 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Stock Spring Rates? (Flux)
This is from memory, but I'm pretty sure it's:
247 lbs/in linear up front
up to 247 lbs/in progressive in back
Warren
Old Dec 30, 2001 | 03:40 PM
Flux's Avatar
Default Re: Stock Spring Rates? (Warren)
Warren
Any idea what that is in kg/mm? (my math skills are long, long forgotten...)
Old Dec 30, 2001 | 03:45 PM
TypeR 599's Avatar
4.3 kg/mm?
Old Dec 30, 2001 | 05:44 PM
Warren's Avatar
Wrong-Way Wang
247 lb/in * .453 kg/lb * 25.4 mm/in = 2.8kg/mm if I didn't screw up, which is entirely possible.
Warren
Old Dec 30, 2001 | 05:51 PM
Kengs's Avatar
4.4 kg/mm (I think).
Old Dec 30, 2001 | 06:09 PM
Michael Delaney's Avatar
247 lb/in x 1 kg/2.2 lb x 1 in. /25.4 mm = 247/ 55.88 = 4.42 kg/mm
Not that Sport Compact Car is ever accurate or anything but in the March 2001 issue they did the cars of Speedvision Touring Car including the Realtime ITRs and there they stated stock ITR spring rates were 225 lb/in. front and 180 lb/in. or for us metric countries (which is not the US and the UK) 4.03 kg/mm front and 3.22 kg/mm rear.
The Realtime ITRs were claimed to be using 800 lb/in. (14.3 kg/mm) front and 1200 lb/in. (21.5 kg/mm) rear....like Jerome Zimmerman is going to tell them exactly what spring rates they use. When I talked to Roger Foo at Mosport, he even told me they got the story on how much his Civic costs all wrong....oh well....
Old Dec 30, 2001 | 06:11 PM
Default Re: Stock Spring Rates? (kengs)
hey kengs, did anyone ever tell you that your avatar is quite distracting?
Old Dec 30, 2001 | 06:31 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Stock Spring Rates? (Michael Delaney)
Whoops. I did screw up, thanks Michael. Last part that I did was wrong. I did mm/in not in/mm.
Warren
Old Dec 30, 2001 | 11:46 PM
yoshi234's Avatar
I shoot brides
does anyone know if our cars has the 96spec or 98 spec springs?
96 spec = 4.3kg/mm
98 spec = 4.4kg/mm
I'm assuming it's the 96 spec b/c we have the 96spec rear sway bar.
yoshi - who jus gut hom flom wachin lawd of da lings fo da secund tajm
fg2si!kid
Honda Civic (2001 - 2005)
Nov 23, 2006 06:12 PM
serious
Mar 28, 2003 07:10 AM
user 9782082308
Jan 16, 2003 07:25 AM
slimbo
Oct 16, 2002 11:22 PM
