H1 ITR trans???
3rd gear pops out while throttle steering......I can hold it in gear and there isn't any grinding, ect...3rd gear syncros where just replaced along with the sleeve set.
Are there aftermarket syncro's? cryo? ???
Paul
Paul, Didnt Mike say he knew a good transmission guy? I am not sure I would keep taking it back to the same place to get the tranny worked on. It seems like they are not fixing the problem.
I'm taking mine to gear speed for a rebuild in a couple months based on both there rep and there work which iv'e driven.
check them out
http://www.gear-speed.com
check them out
If your mounts are good it is probably an internal trans issue. I know a Honda technician that does our (Hasport's) trannys here in Phoenix if you need some help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaulB »</TD></TR><TR><TD CLASS="quote">
Paul</TD></TR></TABLE>
Yes SMSP makes syncros for ITR trannys.
Juans_MX3
Apr 10, 2010 06:27 AM
ABlais
12
Jun 17, 2008 11:25 AM
GroundZer0 336
12
Jun 4, 2003 11:17 AM
