will this fit?
Old Nov 29, 2004 | 04:23 AM
eymnewdc4's Avatar
Default will this fit?
a friend of mine has a gsr with an Apex-i N1 catback that i want to buy. but i have an LS. will it still fit? that would suck if it doesnt.
Old Nov 29, 2004 | 04:56 AM
Integrt's Avatar
Default Re: will this fit? (eymnewdc2)
nope. exausts are diff lengths. sry
Old Nov 29, 2004 | 05:02 AM
FULL-REV's Avatar
I am not sure because i have my skunk2 mega power exhaust cat back from a 00 GSR and it fit fine. Hmmmmm
Old Nov 29, 2004 | 05:11 AM
furious94ls's Avatar
Default Re: (hondaevo)
If your friend has an 00-01 GSR and you have a 94-95LS then it will bolt on perfectly. If not then you have to make adjustments.
Old Nov 29, 2004 | 05:15 AM
tig3rxiong's Avatar
yep.
Old Nov 29, 2004 | 06:03 AM
dFreezy's Avatar
Default Re: (furious94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls &raquo;</TD></TR><TR><TD CLASS="quote">If your friend has an 00-01 GSR and you have a 94-95LS then it will bolt on perfectly. If not then you have to make adjustments. </TD></TR></TABLE>all non-vtec exhausts have the same dimensions from 94-01.
Old Nov 29, 2004 | 06:20 AM
StolenTeg's Avatar
Default Re: (dFreezy)
Exhaust from an 00-01 GSR is a direct bolt-on for 94-01 LS, If the GSR is 94-99, Bring the exhaust too a muffler shop. It shoundt be a hard fix.
Old Nov 29, 2004 | 07:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">all non-vtec exhausts have the same dimensions from 94-01.</TD></TR></TABLE>
It has to do with the header length. For the 94-95 LS it is the same as the 00-01 GSR. 96-01 LS is different, and so is 96-99 GSR.
Old Nov 29, 2004 | 07:29 AM
dFreezy's Avatar
the difference isn't enough to need to make adjustments, especially on just a catback system. thats why any aftermarket exhaust for a non-vtec integras says they will fit 94-01, 00-01 gsr's, or 97-01 itr's.
Old Nov 29, 2004 | 07:43 AM
HONDA RR's Avatar
I TIRED THIS BEFORE AND IT DID'NT FIT EXCEPT I USED A TYPE R CAT BACK SYSTEM AND TRIED TO MAKE IT FIT A GSR.
Old Nov 29, 2004 | 08:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">the difference isn't enough to need to make adjustments, especially on just a catback system. thats why any aftermarket exhaust for a non-vtec integras says they will fit 94-01, 00-01 gsr's, or 97-01 itr's.</TD></TR></TABLE>
This is why it will work. If it is from an older GSR it will need to be customized to the length in the header. The OO-01 GSR is the same length as the 94-01 LS header length. 94-99 GSR is different.
EDIT: I see where I made my mistake where you quoted me. I said 94-95 LS. Should have read 94-01
Old Nov 29, 2004 | 09:48 AM
yee SERIOUS's Avatar
wouldn't 96-99 gsr's have a different down pipe than 94-95 cause of obd2 o2 bung being on the end of it like the 00-01 gsr's.
get the n1 anyways. it won't be too hard to make it bolt up. muffler shop will fix everything for less than 30 bucks i bet.
and if u don't buy it, i will.
Old Nov 29, 2004 | 10:20 AM
eymnewdc4's Avatar
Default Re: (LiTtOGPiMp)
i can cut and weld myself. i just dont know where to cut and weld to where it wont cause a problem. and what kind of extension should i get? i know the N1 is 60mm .... so how should big (or small) should i get of an extension. i know that diagram was a big help, but does anyone have actual measurements on the size difference? if not .... ill just climb uner there, unbolt it, lay em next to each other and measure all of the pipes.
....wow, this is getting confusing. maybe i should just let a muffler shop do it.
Old Nov 29, 2004 | 10:23 AM
Sack Master's Avatar
Default Re: (eymnewdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eymnewdc2 &raquo;</TD></TR><TR><TD CLASS="quote">....wow, this is getting confusing. maybe i should just let a muffler shop do it.</TD></TR></TABLE> It's usually only like $20.
Old Nov 29, 2004 | 10:32 AM
95LSDOHC's Avatar
Default Re: (Sack Master)
actually...i bought a 94-00 gsr worldsport for my ls...cause i couldnt turn down the price....i cut and welded it so it would be the right length....but for some reason mine hangs extremely low...im talking like barely 2 inches off the ground towards the middles of the car....im not sure y but im in the process of fixing it...your best bet i would say is to just pick one up for an ls....save urself the time and possible problems u might run into
Old Nov 30, 2004 | 09:06 AM
eymnewdc4's Avatar
well i called a shop and they charge $72 an hour. maybe i can get some guy after hours to do it for a case of beer?
Old Dec 1, 2004 | 08:35 AM
eymnewdc4's Avatar
........what if i go with a GSR header/stock manifold? im wanting to upgrade anyway.....
Old Dec 1, 2004 | 09:55 AM
eymnewdc4's Avatar
^bump^ help
Old Dec 2, 2004 | 11:06 AM
eymnewdc4's Avatar
"bump"
plz help.
dfer2190
Aug 12, 2008 07:16 AM
DC2uned
Jun 13, 2005 09:30 PM
B18-Mike
Feb 1, 2005 11:15 AM
StolenTeg
Jun 28, 2004 07:43 PM
GSRBoy
Nov 19, 2003 06:11 PM
