can this set up make power?????????
WHAT ARE SOME NUMBERS TO EXPECT
the block is a b18a and i got it buit weeks ago basically it 12to1 compression has Golden Eagle Iron Sleeves, Wiseco pistons 85mm, Eagle connecting rods, Bore & Hone, Hot tank, Deck, Balance and Micro Polish LS Crank shaft
the head is off a 98 gsr modifications are.Degrease/clean cylinder heads, Port and polish, Deshroud valve and chamber area, Polish chamber, 3 angle valve job running skunk2 stage 2 with crower spring Im also have a set of twm individual throttle bodies with 440cc injectors that are going on as for the tunning runing hondatas100.
any set ups the same list them please any info r whatever is cool! just tring to c what else should i do
Modified by sloboy_joe at 11:49 AM 11/29/2004
