how can i fix a code 10 in my eg hatch
Well, replace the sensor, or before that even check to make sure that all of the wires are connected all right. Other than that, I don't know that there is another way around it. The only other thing is to think of anything you may have done to cause the sensor to come on (modify something, change something, etc).
-Shane
-Shane
does idle air temperature sensor IAT ring a bell? It's the white sensor on your intake manifold. replace it reset your ecu and you should be good to go.
