Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
5th gen accord wheels size 16" or 17"
Old Nov 28, 2004 | 08:24 PM
xxmaxhardcorexx's Avatar
Default 5th gen accord wheels size 16" or 17"
I was thinking about going down to 16"s wheels, and i guess my question
is, on a 94-97 accord is there a tire/wheel combo in 16" that would be better
for all around performance VS a 17" set up? i know accelaraiton is going to be better, but can someone give me a bit of info? i always thought 16" were to small
but i dont know?
Old Nov 28, 2004 | 08:34 PM
Vanilla Ic3's Avatar
Default Re: 5th gen accord wheels size 16" or 17" (xxmaxhardcorexx)
15". OWNAGE!
What are you going to be using this car for exactly?
Old Nov 28, 2004 | 08:41 PM
Default Re: 5th gen accord wheels size 16" or 17" (Vanilla Ic3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vanilla Ic3 &raquo;</TD></TR><TR><TD CLASS="quote">15". OWNAGE!
What are you going to be using this car for exactly?</TD></TR></TABLE>
had 15" and slid all over the place,
I would like to keep it a street/open event (road race) set up.
the car makes over 300HP so would that be a factor or should i just stick with the 17"
Old Nov 28, 2004 | 08:57 PM
Evan55's Avatar
anything less than 18" is for wannabes
Old Nov 28, 2004 | 09:01 PM
Default Re: 5th gen accord wheels size 16" or 17" (elgorey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elgorey &raquo;</TD></TR><TR><TD CLASS="quote">anything less than 18" is for wannabes</TD></TR></TABLE>
ahhh, thanks
Old Nov 29, 2004 | 05:41 AM
Sean O'Gorman's Avatar
Hey, quit giving bad advice! 18"s are so 1999. 20" or larger now! And get the big blingy brakes, too. The more holes drilled in them, the better. They are perfect for open event road races.
Old Nov 29, 2004 | 07:46 AM
Default Re: 5th gen accord wheels size 16" or 17" (Sean O'Gorman)
Honda tech is going down the tubes, i guess if people dont know a awsner
they try to 1 up you.That or the people that come to this fourm talk about the same **** over and over and dont know anything other than what they read from other people or a magizine.If you cant help me out, then dont post your shitty
comments.
Old Nov 29, 2004 | 08:03 AM
mos's Avatar
mos
There are a lot lot more tire choices in 17" although that might not matter to you if you find exactly what you are after in 16". Street/DE sounds like a job for the Azenis. I'm going to assume you are running 7" wheels? The new 16" azenis are available only in 205mm x 40% me thinks. You can get 215 or 235mm in 17's.
I think part of the reason you are getting those replies is that you did not give much detail in your original post. Not enough information to reply with a good answer. Well, that and your username.
Old Nov 29, 2004 | 09:52 AM
bad-monkey's Avatar
mos is right, and good 16" tires are getting harder to find.
15's are fine, if you get the right tire in that size. I don't think you've got a brake clearance issue so 225/50/15 azenis/BFG TA KD's/or other good tires + 15x7/7.5/8 will prob do you right. it's much cheaper buying rubber in 15" sizes too.
but if you're set on 16 or 17 i'd say stick with the 17.
Old Nov 29, 2004 | 12:09 PM
rapid_roy's Avatar
Default Re: 5th gen accord wheels size 16" or 17" (mos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">Well, that and your username. </TD></TR></TABLE>
But what if he *really is* Max Hardcore
Old Nov 29, 2004 | 01:16 PM
Solracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">
the car makes over 300HP so would that be a factor or should i just stick with the 17"</TD></TR></TABLE>
Where and what tracks are you driving at?
Old Nov 29, 2004 | 09:15 PM
Default Re: 5th gen accord wheels size 16" or 17" (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">
Where and what tracks are you driving at?</TD></TR></TABLE>
button willow,i would say mostly (again this is a street car) so i will not be doing any hardcore racing, just somthing to take out every once and a while and cruz aroud the canyons. i have some heavy *** work wheels 17x7 on azines st115's
they grip ok i guess but i want somthing smaller wider, i looked at 16" tire and
could not find to much to choose from in a 225 with,Nothing stickey anyways.
i had 15's about 2 years ago and did not like them they felt sloppy for handeling
but then again i havent had a lot of track time. i guess my question is can i go wrong with keping 17"s or is there any advantage to going down to 16" for what i'm looking for.
Old Nov 30, 2004 | 04:47 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">cruz aroud the canyons. </TD></TR></TABLE>
Old Nov 30, 2004 | 05:50 AM
azian21485's Avatar
just the fact of running 15's alone doesn't mean you will have sloppy handling..what kind and size of tires did you have when you ran them and how wide were the rims?
throw on a set of 205/50/15 on 15x7 rims and see if they feel sloppy
new azenis are coming out in 225/50/15 as stated earlier so you should look into those
Old Nov 30, 2004 | 06:51 AM
Evan55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">Honda tech is going down the tubes, </TD></TR></TABLE>
I agree, fucktards posting stupid questions in the wrong forum. Now GTFO
Old Nov 30, 2004 | 07:32 AM
I agree, fucktards posting stupid questions in the wrong forum. Now GTFO</TD></TR></TABLE>
the reason i dont post in the accord fourm is because no one knows any thing
so i thought this would be the place to ask, but being your such a *******
i assume you dont know **** your self, so why ******* post your useless ****.
I ******* hate people like you,"whoa look at me...i'm hardcore,i take **** serious!"
LOL..you ******* *****....
Old Dec 2, 2004 | 07:32 AM
Solracer's Avatar
LOL..you ******* *****....</TD></TR></TABLE>
Actually since you stated your main purose was toogay your the *****, we only dicuss legal Racing and hpde events in here so don't let the door hit you in the ***.
Old Dec 2, 2004 | 08:09 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">the reason i dont post in the accord fourm is because no one knows any thing
This guy is sharp as a marble...
Old Dec 2, 2004 | 11:33 AM
Calm down, junior.
Yeah many people here (myself included) tend to be excessively harsh on some people, but if you can laugh at it and learn from it, they'll accept you pretty quickly.
Old Dec 2, 2004 | 07:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean O’Gorman &raquo;</TD></TR><TR><TD CLASS="quote">
Calm down, junior.
Yeah many people here (myself included) tend to be excessively harsh on some people, but if you can laugh at it and learn from it, they'll accept you pretty quickly.</TD></TR></TABLE>
ACCEPT ME? are you kidding me? LOL!
The funny thing is how people assumed i was a street racer because i mentioned
that i drive around the canyons, like i said i race there,or because the car is a accord so i get accused for having some ricer bling ****....
Getting harsh with people on the internet is useless, i'm not going to have a pissing
contest with a bunch of 20 year old kids.if you dont understand what i write dont post., very simple.So for the people who helped thanks.
Old Dec 2, 2004 | 07:44 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">The funny thing is how people assumed i was a street racer because i mentioned that i drive around the canyons, like i said i race there........ i'm not going to have a pissing contest with a bunch of 20 year old kids.</TD></TR></TABLE>
You arent getting it are you. Garbage in = garbage out.
Street jackassery just isnt tolerated here and no one is going to help you with making your car handle better for the "cany0ns y0!". Also, there are very very few "20 year old kids" in this group - most of us are a bit older (and some a lot older... with many years of real race experience) - and the level of maturity of the people of maturity in this forum is clearly higher than yours - sorry if you cant handle that. If you come in talking ****... dont expect any help.
Old Dec 2, 2004 | 08:00 PM
Default Re: 5th gen accord wheels size 16" or 17" (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Street jackassery just isnt tolerated here and no one is going to help you with making your car handle better for the "cany0ns y0!". Also, there are very very few "20 year old kids" in this group - most of us are a bit older (and some a lot older... with many years of real race experience) - and the level of maturity of the people of maturity in this forum is clearly higher than yours - sorry if you cant handle that. If you come in talking ****... dont expect any help.</TD></TR></TABLE>
So again where do you come up with this street jackassery? i never said
i race in the cayons. i'm not allowed to drive around there when there is nothing to do? or do cool people not go at all?is that what you are telling me?
The fact is you guys try to "one up" every one.You came in saying i was a canyon racer. i never said i race there.You can say what ever you want, for the people who know me here know i'm a calm honest guy and do not talk **** unless i'm pushed, i asked a simple question and got attacked for no reason. so you can take your "canyons YO" and stick it up your ***.People like your self talk **** on the internet, but i bet if you were face to face with me you would not talk ****,because if you did, i would break my foot off in your ***. so talk all you want because thats all your good for, i'm done here,Jackass
Old Dec 2, 2004 | 08:02 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">People like your self talk **** on the internet, but i bet if you were face to face with me you would not talk ****,because if you did, i would break my foot off in your ***. so talk all you want because thats all your good for, i'm done here,Jackass</TD></TR></TABLE>
lol.... e-thugging at its finest. You're so super!
Old Dec 2, 2004 | 08:38 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmaxhardcorexx &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking about going down to 16"s wheels, and i guess my question
but i dont know?</TD></TR></TABLE>
I've got a 295 WHP Integra that does just fine on 205-50 R15's.
I've heard *ahem* that 16" tires are hard to come by, at least for Integras. Your tires are taller, and Tire Rack lists a chitload of 205/55 R16's, and even more 225/50R16's (just looking at Max Performance and Competition).
You can tighten up the 'feel' of a car with 17's, and maybe that's what you want, but the ligher (prolly 16") combo will likely be faster, and stiffer sidewalls on good tires will also negate some of the advantage of a really low profile tire.
Now GTFO
Edit: With more power, your tires are going to probably heat up more, a wider tire will help compensate for that. But that's more weight and aerodynamic drag. YMMV.
Old Dec 2, 2004 | 10:48 PM
azian21485's Avatar
you need to calm down...there were a few posts of people trying to help you but you ignored those posts and chose to respond to the other threads that weren't helping out your situation, thus you made the problem worse by not answering the questions of those trying to help you and continued to respond to offtopic comments
you are still being vague btw
