how do you distinguish between pressure plate or clutch problem????
My 91 dx is having a little weird problem. When the car is cold the clucth grabs great and everything, but when it gets hotter as you use it (15-20min) its like the clutch starts slipping. It still runs ok but not grabbing like it should. What should I check???
thanks
l8er
thanks
l8er
If the clutch has a load of miles on it, it might be due to be replaced. Thats replace the clutch plate AND pressure plate.
project_ek9
May 6, 2010 08:01 AM
