JDM folding mirror install site???
Can't find the site I had bookmarked on installing the folding JDM mirrors (BB4) - searched the site & web - to no avail; just wonding if anyone knows of a good site with instructions - thanks
also, if anyone has them, anything i should know before buying? pain to install, etc
http://www.preludeonline.com/s...iring
the main write up is no longer there but berticos wiring diagram will get you through
all u need to do is use the harnesses off of you usdm mirrors and follow the wiring parts the mirror control wires are the same for usdm to jdm so it will not matter all u need to do is wire the folding feature up and that is simple +,- to blck and white wire on each jdm mirror then wire the relay up to the orange or yellow wire on your radio --- and the negative on your radio as well the green wire from the mirror control button goes to the relay
you will need jdm mirrors, folding mirror button switch, and a jdm prelude (not integra/civic) relay very rare I found mine off of ebay for 35 bucks
GOODLUCK ---
GOODLUCK ---
