LSD in an S1 tranny
what stock Honda LSD can I drop into my S1 without major mods...I was devoured by an EG with Type-R tranny on B16...I have S1 with the same gears and no LSD... help me out!!!!
type R LSD would work with your S1 tranny or any other B series trannys that has LSD. We carry Quaife-Limited Slip Differental. The Quaife-Limited slip differental transfers power to both wheels instead of just one like most open differentals that come on stock cars. Less power wasted and faster acceleration.
please give us a call
A factory LSD from a Y1 will drop in with no mods. However, in order to use the ITR diff and ring gear, you will need to grind the case significantly in order to use the MUCH LARGER ITR diff. The ITR/GSR size diff IS NOT a drop in mod.
