Question About Rear Motor Mount Bolt
Old Nov 28, 2004 | 03:08 PM
RedTurboITR's Avatar
Default Question About Rear Motor Mount Bolt
I need to retap the bolt and wanted to double check it was the right pitch and thread. is it 10X1.25? just want to make sure. thanks
-denny
Old Nov 28, 2004 | 03:22 PM
Default Re: Question About Rear Motor Mount Bolt (RedTurboITR)
to make it more clear, its the 2 bolts that bolt the actual motor mount down. the nut size is 14mm if that helps
Old Nov 28, 2004 | 03:45 PM
Dropspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTurboITR &raquo;</TD></TR><TR><TD CLASS="quote">to make it more clear, its the 2 bolts that bolt the actual motor mount down. the nut size is 14mm if that helps</TD></TR></TABLE>
To Clarify: Hold the rear motor mount to the Subframe just above the steering rack?
Mattj
Old Nov 28, 2004 | 03:46 PM
Default Re: Question About Rear Motor Mount Bolt (Dropspeed)
you can see the bolt in that pic. its the one closest to the firewall.
Old Nov 28, 2004 | 04:27 PM
i dont have my helms handy so i was hopeing somebody can take a quick look for me
grog
Apr 25, 2008 06:44 AM
allmotorh22
Nov 24, 2006 08:30 PM
mkazm83
Jan 28, 2006 04:46 PM
Mr.Saturn
Feb 13, 2004 02:50 PM
DMF
Oct 12, 2003 09:30 PM
