how much does acura charge for CEL inspection ?
i've had these 2 CEL's 67 and 91 for awhile now and i kinda wanna keep my car in top notch shape now cause the CEL's have been there for almost a year. i was wondering how much does the acura dealership charge for inspection of whats wrong??
Take it to the dealership if you want to get raped. I didn't bother to look up those CEL's but getting those is half the battle. Look them up, that'll give you a good idea as to what's wrong.
From: hittin corners so hard you can taste my rims..
its usually $70 for a diagnosis inspection..
but your codes dont' sound framilure.. do you know how to grab CEL's correctly? maybe your not reading the lights right.
i think they charge like an hour or so flat rate for diagnostic. so, for 2 codes, it'll be about $150-200 only to find out whats wrong. whatever they do to fix it would be extra.
How old is your car? 67 usually is a bad cat and 91 could be a bad sensor or vacuum leak, but thats just my guess based upon the code. Take it to a dealership if you want your car in top notch shape because they will do the best work, but it will cost the most.
you can do it yrself. search H-T or i can copy and post the instructions later when i get home.
however, its gonna come back unless you fix what caused it in the first place...
