Newbie to ITB's...Need some help
I was wondering how much of a CR do you need to effectively make the ITB's work? TWM in particular if that helps
The Setup it will be going on:
B18C1 bottom w/ jdm itr pistons
2 layer headgasket
GSR Head w/ JUN 3 cams <-----i dont even know the exact CR of this setup either
2 layer headgasket
I am not sure on your exact setup but you should around 12:1 (guessing). From other peoples experience, and my own, you are at your limit for running 93 octane. If I ever finish my project I will be running an almost identical setup with TWM throttle bodies with high goals of 220whp.
My point is your compression ratio is high enough for the street. I would say go ahead with the trottle bodies.
i was planing on running 100 octane anyway, but another thing i was curious about if i do you use whack @$$ 91 octane w/ the setup i plan on running will there be detonation even if i just drive regularly say to and from work w/o plans of ******* the motor anyway...will there be detonation for sure still???
