96 dx Hatch
Old Nov 28, 2004 | 01:32 PM
SIcoup's Avatar
Default 96 dx Hatch
Hey guys,
Ive just bought a 96 Dx hatch, with low milege. I happen to have a 96 Si head in my garage. 1st can the si head be mated onto the dx block, if so what is involved and is it worth the hassle. 2nd what would the general gain be?
Thanks.
Old Nov 28, 2004 | 01:37 PM
slow94coupe's Avatar
Default Re: 96 dx Hatch (SIcoup)
if your talking about putting a single vtec head on a single non vtec motor then where have you been for the past 10 years. jk yes you can do this search.
smithenhiven's Avatar
11:11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIcoup &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
Thanks.</TD></TR></TABLE>
I don't think there was an SI civic made in 96. Do you mean 95? If so, then yes, it will mount up to your DX block, but you may run into some wiring problems with the head being OBD1
Old Nov 28, 2004 | 01:48 PM
EK k kay's Avatar
Default Re: 96 dx Hatch (smithenhiven)
Maybe he's talking about the 96 del sol si head? That'd be the z6 head. Or he could be in Canada in which the Si = U.S. EX.
Old Nov 28, 2004 | 01:57 PM
SIcoup's Avatar
no 96si??? what is the d16y8???
Old Nov 28, 2004 | 02:25 PM
fishnfst's Avatar
The only 96 si was a del sol and it had a b16 in it if this is the head he has no it wil not mate up to his D series block......sicoup the y8 did not come in any si trim level ever. It came in the ex civics and thats it.... The lx, dx ,cx came with the y7's hte 99-00si were all b16's.
Old Nov 28, 2004 | 02:36 PM
d16rice's Avatar
Default Re: (SIcoup)
If you are putting a d16y8 head on a d16y7 engine block, then yes, it is doable, but it's pretty involved. You'll need everything from engine block up + extra wires and ecu.
I'm doing it on my '97 hb, too.
Some of the things you’ll need are:
D16Y8 Head (with all internals)
D16Y8 Intake manifold (throttle body, injectors etc..)
P2P ECU
A few extra wires
And a lot of patients.
Supposedly, an adjustable cam gear is very helpful when tuning this contraption.
Also, although not necessary, might as well get a set of headers, too, if not for performance, then at least for looks
Good luck.
Old Nov 28, 2004 | 03:01 PM
EK k kay's Avatar
Default Re: (d16rice)
d16y8 is an ex motor. I am also doing the d16y8 headswap onto my 99 dx hatch. I plan on doing this within 2 weeks. Just waiting on some parts to arrive.
Old Nov 28, 2004 | 07:00 PM
TurboTagTeam's Avatar
Are you talking about buting a B16a2 head on a d16y7? why do that?? just put on a y8 head, id be way less hasle
Old Nov 28, 2004 | 10:11 PM
DSM 4g63's Avatar
i say u slang the si head.. save feds and juss buy either a b series or k series motor.. its really up to u.. id juss do that... yeah its a lot of werk.. ba yet it still pays off in the end u kno! ull be faster then a dx block with an si head!
but other then that... IM ALL BEHIND U ON THE SI HEAD MAN!
Old Nov 29, 2004 | 03:55 AM
d16rice's Avatar
Default Re: (vtecNrevrse)
First of all, there is no way to put a twin cam head (D, B, H, K, what ever) on a single cam (D) engine block. The only D series twin cam engine is the ZC, and its engine block is different from all other D series block, so you can't even bolt that head to a d16y7.
The reason people are doing these head swaps are because of a few reasons.
1. Easier
2. Less time consuming
3. CHEAPER
A full d16y8 engine swap cost a little over $1,000 ( ),
a B swap is around $4,000 ( ),
and K is still up in the $7,000 range ( ),
where as a y8 head swap on a y7 block could be done for under $500 ( ). best bang for the buck. Aside from nitrous, you’ll be hard pressed to get 20hp gain for under $500.
Old Nov 29, 2004 | 04:22 AM
11:11
Default Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">The only 96 si was a del sol and it had a b16 in it if this is the head he has no it wil not mate up to his D series block......sicoup the y8 did not come in any si trim level ever. It came in the ex civics and thats it.... The lx, dx ,cx came with the y7's hte 99-00si were all b16's.</TD></TR></TABLE>
The B16 Del Sol's where called the Del Sol VTEC's. The Si Del Sol's had the D16Z6.
project_legacy
Oct 18, 2005 10:54 PM
blacksniper
Jun 28, 2004 05:58 AM
danny
Jun 7, 2002 10:40 PM
pdiddy
Feb 21, 2002 12:42 PM
