What is the correct Ls/Vtec oil line suppy size?
Old Nov 28, 2004 | 09:20 AM
GDM Z28's Avatar
Default What is the correct Ls/Vtec oil line suppy size?
ok alot of people say that 4AN is the right size and alot say 6AN is the right size. Now what do you think is the right size and why? Dont just put "6AN cause thats what im using". Give a reason. Also what could happen if you use too small or too big of a size? TIA
-Trent
Old Nov 28, 2004 | 12:52 PM
GDM Z28's Avatar
Default Re: What is the correct Ls/Vtec oil line suppy size? (civicflnum1)
TTT
Old Nov 28, 2004 | 03:13 PM
eg6T's Avatar
**** i want to know because i just ordered a bunch of 4an line for my ls/vtec..god please let it be 4an
i know they used 4an for the ls/vtec build on c-speedracing.com
Old Nov 28, 2004 | 03:25 PM
drdisco69's Avatar
Default Re: What is the correct Ls/Vtec oil line suppy size? (eg6T)
It's impossible to make it too big, unless the hood won't close.
Considering the size of the oil feed to the head, and the tiny volume required by the vtec system, I would say that 4AN would be enough. I've used that on a motor, and it was fine. The oil drain is tiny anyway, and so is the fitting on the back of the block.
Old Nov 28, 2004 | 03:42 PM
GDM Z28's Avatar
Default Re: What is the correct Ls/Vtec oil line suppy size? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">It's impossible to make it too big, unless the hood won't close.
Considering the size of the oil feed to the head, and the tiny volume required by the vtec system, I would say that 4AN would be enough. I've used that on a motor, and it was fine. The oil drain is tiny anyway, and so is the fitting on the back of the block.</TD></TR></TABLE>
how long did that motor last n why did it fail? I have a 4an line so i hope that was it
Old Nov 28, 2004 | 03:47 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">how long did that motor last n why did it fail?</TD></TR></TABLE>
A little skeptical aren't we? The motor lasted long enough for me to want a type r block and rev some more, around 5k miles. It didn't fail, I just didn't like it.
Old Nov 28, 2004 | 04:15 PM
GDM Z28's Avatar
A little skeptical aren't we? The motor lasted long enough for me to want a type r block and rev some more, around 5k miles. It didn't fail, I just didn't like it.</TD></TR></TABLE>
oh ok....well i built this one for boost (je and eagles) and other goodies so i just dont wana see it fail due to a stupid small hose lol.
Old Nov 28, 2004 | 04:19 PM
drdisco69's Avatar
It won't fail, the worst that can happen is that is that vtec won't work. But it will.
Old Nov 28, 2004 | 04:47 PM
quik1's Avatar
All you need is 4an line, you don't need to flow lots of oil so a small line is fine.
Old Nov 28, 2004 | 04:49 PM
GDM Z28's Avatar
Default Re: What is the correct Ls/Vtec oil line suppy size? (quik1)
ty guys!
Old Nov 28, 2004 | 08:32 PM
JDMotive's Avatar
-4 or -6 will be fine...on the engines I build with shimmed oil pumps,I run a -6.
Old Nov 28, 2004 | 08:40 PM
UnKnownUser's Avatar
Default Re: What is the correct Ls/Vtec oil line suppy size? (JDMotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">-4 or -6 will be fine...on the engines I build with shimmed oil pumps,I run a -6.</TD></TR></TABLE>
Touge Tuning
Jul 25, 2006 04:16 PM
riceball777
Dec 2, 2003 08:05 AM
paulzy
Jun 20, 2002 01:55 AM
