Tire rub Problem
Old Nov 28, 2004 | 08:22 AM
harwood39's Avatar
Default Tire rub Problem
I lowered my 95 Civic coupe about 2-3 inches and now the stock tires rub. Its not slicing or damaging the tires. is there anyway to fix this without raising the car? Should i even worry about it if its not damaging the tires?
Old Nov 28, 2004 | 08:35 AM
jlacoy82's Avatar
71.192.16.183
Default Re: Tire rub Problem (harwood39)
Roll the fenders.
Old Nov 28, 2004 | 08:52 AM
Essenar's Avatar
Default Re: Tire rub Problem (jlacoy82)
I hate to post here like this but;
Why can't I freakin' post in any of the topics other than this forum? it says I don't have permission to post in any forums in the market place and I want to contact sellers or make WTB topics but I can't
Old Nov 28, 2004 | 09:04 AM
crashN2u's Avatar
Default Re: Tire rub Problem (Essenar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Roll the fenders.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Essenar &raquo;</TD></TR><TR><TD CLASS="quote">I hate to post here like this but;
Why can't I freakin' post in any of the topics other than this forum? it says I don't have permission to post in any forums in the market place and I want to contact sellers or make WTB topics but I can't </TD></TR></TABLE>
Next time search instead of jacking someones thread. It's cause you're still a trial member.
Old Nov 28, 2004 | 09:09 AM
thid92's Avatar
can I haz?
if you would read the forum rules, it says that you have to be a trial member for an X amount of days before you become a member and there for you can not post in forums where it says members only.
Old Nov 28, 2004 | 09:58 AM
harwood39's Avatar
Default Re: Tire rub Problem (thid92)
Its not rubbing on the outside part of the fenders, its rubbing on the inside part, where all the rubber coating is, plastic inners, and the frame. The front rub a lot on the inside when turning. I know i will need to roll the fenders to get my 16x7's in there, but will i also need to get spacers so it doesnt rub when turning?
Old Nov 28, 2004 | 10:27 AM
jlacoy82's Avatar
71.192.16.183
If its rubbing that badly on stocky's, its only going to be worse with larger and wider tires on there. I dont know if you can take the fender liners out, I'm sure somebody else will know, that might HELP your problem a bit?
Old Nov 28, 2004 | 10:49 AM
crashN2u's Avatar
Default Re: (jlacoy82)
You have to take out the little plastic liners to roll the fender. If you just take them out without rolling it'll start to cut into the tire depending on how low it is. I would just raise it a little if you have coilovers and add a lip and skirts to get the same lowered look.
stage3porkandpolish
Jul 10, 2006 03:04 AM
dohcVTECeg3
Dec 3, 2005 09:34 PM
boosted civic 2k6
Sep 22, 2005 08:25 AM
jok3sta
Mar 9, 2005 03:28 PM
