OBD2 distributer/injectors?
Old Nov 27, 2004 | 11:28 PM
Phase2's Avatar
Default OBD2 distributer/injectors?
this might be a noob question, but i need to know.
heres my situation.
I have a 2000 Civic hatch. im putting a JDM B18C into my car, but the motor is in a 89 CRX.
this is what i plan on doing.
getting a 99-00 Si engine harness, and using a P28 with a OBD2-OBD1 conversion harness.
heres the problem.
i can get ahold of OBD2 injectors and an OBD2 distributer.
can i use these with the setup im planning on doing?
thanks in advance.
Old Nov 28, 2004 | 06:23 PM
Phase2's Avatar
Default Re: OBD2 distributer/injectors? (Phase2)
up
Old Nov 28, 2004 | 06:29 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase2 &raquo;</TD></TR><TR><TD CLASS="quote">can i use these with the setup im planning on doing?</TD></TR></TABLE>
yes. Since your going obd 1 just get some obd 1 injectors and an obd 1 dizzy.
If you prefer obd 2 injectors and dizzy that will also work.
Old Nov 28, 2004 | 06:32 PM
Phase2's Avatar
Default Re: OBD2 distributer/injectors? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
well, the thing is, i CAN get OBD2 injectors and distributer right now, but im just wondering if they will work fine with my P28.
would you guys <U>recommend</U> using OBD1 injectors/distributer?
Old Nov 28, 2004 | 06:46 PM
eda6's Avatar
well, the thing is, i CAN get OBD2 injectors and distributer right now, but im just wondering if they will work fine with my P28.</TD></TR></TABLE>
Go for it. They will work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase2 &raquo;</TD></TR><TR><TD CLASS="quote">would you guys <U>recommend</U> using OBD1 injectors/distributer?</TD></TR></TABLE>
To my knowledge the only difference is the plugs on the dizzy. Obd 1 dizzy has two plugs and 0bd 2 dizzy has one plug.
Old Nov 28, 2004 | 06:57 PM
Phase2's Avatar
can i also use a OBD2 Vtec Solenoid?
Old Nov 28, 2004 | 07:04 PM
mmuller's Avatar
Mad Scientist
yes
Old Nov 30, 2004 | 07:25 PM
Phase2's Avatar
Default Re: OBD2 distributer/injectors? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
thanks man!
any other input on my situation?
EX-T
Jun 21, 2007 05:16 AM
Power Rev Racing
Apr 20, 2006 06:24 AM
blackeg
Sep 16, 2004 02:52 PM
GSRswapandslow.
Jul 17, 2004 03:20 AM
