blown motor have to rebuild
Old Nov 27, 2004 | 11:25 PM
JDMitr54's Avatar
Default blown motor have to rebuild
alright heres the deal i got a JDM 98spec ITR and i spun a bearing (#1 and 4 to be exact) and screwed my crankshaft, bent a rod, and also screwed my piston and this all happen racing and then got worse cause i didnt notice until later on..
But now my question is because basically my options on rebuildin it r endless and i cant really decide if i should go with the type R style and stay NA or if i should just go again and lower the compression to about 9 and go for turbo. If anyone as any suggestions as to which might be better let me kno.. Just about any helpful in for is wanted..
Old Nov 27, 2004 | 11:34 PM
Bbasso's Avatar
Default Re: blown motor have to rebuild (JDMitr54)
https://honda-tech.com/zerothread?id=766629
Most of everything you will need is there, good luck on the rebuild.
Old Nov 28, 2004 | 04:58 AM
Bradstard's Avatar
I've got a stock crank and stock rods I can sell you if you are on a budget.
s032105k
Feb 25, 2011 12:11 PM
94GSRMR
Jan 1, 2011 07:05 PM
seehad79
11
Feb 14, 2010 04:24 PM
Anon51
Oct 10, 2009 09:53 AM
95jdmej2
Aug 16, 2009 07:00 PM
