obd0-1 conversion....which wire pin is the o2 sensor signal?..hooking up a/f gauge
Old Nov 27, 2004 | 11:23 PM
Gant's Avatar
Default obd0-1 conversion....which wire pin is the o2 sensor signal?..hooking up a/f gauge
i have a d16z6
running a 4wire o2, on the conversion harness which one is the oxygen sensor signal pin?
Old Nov 27, 2004 | 11:28 PM
Gant's Avatar
doh i mean which color wire is the o2 sensor signal on the actual conversion harness..cuase tehres 8 extra wires u hook up to convert to obd1 and i dont know which one to use
Old Nov 27, 2004 | 11:41 PM
Mr_CRX's Avatar
Default Re: (Ba4)
I believe the pin for the o2 sensor is D14. The color probably depends on which conversion harness you have. The pinout I have shows it as being wht/red on the stock obd1 harness if I'm looking at the right one.
Old Nov 27, 2004 | 11:42 PM
Gant's Avatar
yeah i have a boomslang does anyone know which wire color is the o2 signal wire?
ZAKU
Mar 1, 2009 11:30 PM
Hondamonster
12
Jun 21, 2007 08:19 PM
BlueShadow
Dec 1, 2005 08:10 PM
PhatwhipsJDMkits
10
Nov 11, 2004 06:38 AM
SI_Ro
Jan 12, 2004 06:43 AM
