tried searching... itr lcas on ek
i've searched and searched but i can't seem to find out if itr lcas fit on my 96 ek and if there's any benefit. i bent my stock lca and i have a set off of a 98 itr. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsir1 »</TD></TR><TR><TD CLASS="quote">i've searched and searched but i can't seem to find out if itr lcas fit on my 96 ek and if there's any benefit. i bent my stock lca and i have a set off of a 98 itr. thanks</TD></TR></TABLE>
sorry they do not fit. They are about 1" too short.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
sorry they do not fit. They are about 1" too short.</TD></TR></TABLE>
theyll fit but to use the ITR lca, youll need ITR shocks. ITR shocks isnt fork shape at the bottom like civic shocks. they fit inside the lca.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAME= »</TD></TR><TR><TD CLASS="quote">
theyll fit but to use the ITR lca, youll need ITR shocks. ITR shocks isnt fork shape at the bottom like civic shocks. they fit inside the lca.</TD></TR></TABLE>
Good work
Good work
its NOT going to fit on a EK chasis, on EG yes, not on EK!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTREGSIX »</TD></TR><TR><TD CLASS="quote">
Good work
Its been confirmed because i had TEin RA ITR Spec suspension. It got into a roll over and salvaged the suspension. BOught a EK Coupe and didnt fit worth a damn.
Good work
</TD></TR></TABLE>Its been confirmed because i had TEin RA ITR Spec suspension. It got into a roll over and salvaged the suspension. BOught a EK Coupe and didnt fit worth a damn.
you can get a set of CTR LCA and it would work, i dunno why though you would have to switch over to new rear dampers as mentioned.
The itr LCA just wont fit because of the rear damper they are also have incorrect geometry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">you can get a set of CTR LCA and it would work, i dunno why though you would have to switch over to new rear dampers as mentioned.
The itr LCA just wont fit because of the rear damper they are also have incorrect geometry</TD></TR></TABLE>
there is no such thing as CTR LCA. Its the same LCA on all 96+ EK civics. Bushing might be stiffer in the CTR, but how it looks, its the same.
the ek is the lone ranger.
the front itr control arms well mount up but one of the bolt holes are differnt in size
the rear is differnt as well
use 99-00 civic si, its the same thing as ctr plus you can use the sway bar to (same as ctr)
use 99-00 si w/ rear sway bar with your stock ek control arms
One easy way to tell is to look at Integras from the rear and look at your car from the rear. You will notice that the lower Subframe is a lot wider than the civic. but the width of the Integ and civic are the same I think
