volumetric efficiency for b18c?
Old Nov 27, 2004 | 10:25 PM
b18-c-rx's Avatar
Default volumetric efficiency for b18c?
anyone know the volumetric efficiency for b18c?
i've looked but i can't find it. is it like 90%?
Old Nov 27, 2004 | 11:43 PM
b18-c-rx's Avatar
Default Re: volumetric efficiency for b18c? (b18-c-rx)
bumpage!
Old Nov 28, 2004 | 12:40 AM
MR5sARECOOL's Avatar
try posting this in the tech section
Old Nov 28, 2004 | 06:11 AM
BlueShadow's Avatar
Back when I owned my Prelude I did a lot of searching to find out what the H22's VE was.
People will say that in most cases peak VE occurs at peak torque RPM and it is around 70-80% VE, and in most cases that is correct. However VTEC motors are the exception, and they usually have peak VE happening at around peak HP RPM. According to http://www.autospeed.com the peak VE for an H22 is 102% occuring at 7000 RPMs, which is alsowhere the HP peaks at. And for an S2000, the peak VE is 112% which occurs at around 8000 RPM. The SAE did a paper on this and it was the engineers from Honda that found those VE numbers.
http://www.autospeed.com/cms/article.html?&A=1127
Now I know you asked about a B18C, but I'm sure the VE for the B18C is somewhere between 102% and 112% (probably closer to 102%).
HTH
Old Nov 28, 2004 | 06:51 AM
drdisco69's Avatar
Default Re: volumetric efficiency for b18c? (BlueShadow)
For a 1.8 making 200hp at 8000rpm, you get a VE of 103ish. Do your own calculations with this VE calculator:
http://www.coe.uncc.edu/~mdkeena/EngineVE.exe
reyrey2006
18
Oct 17, 2008 10:12 PM
b18-c-rx
Nov 11, 2004 04:46 PM
Diversifiedsalez
Dec 2, 2001 07:59 PM
