Adjusting Headlights
Old Nov 27, 2004 | 08:43 PM
jeffk182's Avatar
Default Adjusting Headlights
I have a 00 Civic Si and I just put in new bulbs and I noticed that my headlights are aiming weird. I know that on the 96-98 civics theres a bubble gauge that shows you how the bulbs are aiming, but on my civic there is no gauge. How do I accurately aim my lights? BTW, my car is lowered so I know that has a small affect.
Old Nov 27, 2004 | 08:49 PM
Resident Evo's Avatar
Default Re: Adjusting Headlights (jeffk182)
Theres a bolt that you can turn behind the headlights. You will need a 10mm wrench.
Old Nov 27, 2004 | 08:53 PM
green-'s Avatar
You can get it close by yourself. Point them at a wall and have at it.
If your a baller, there is a machine that you can use to get them almost perfect. The body shop i used to work at had one, it was neet.
Old Nov 27, 2004 | 08:56 PM
jeffk182's Avatar
So for my car, I just have to do it by eye against a wall pretty much?
And dont you just use a screw driver? Theres 2 places u can adjust..up/down and left/right
Old Nov 27, 2004 | 08:58 PM
SOHC4life 96's Avatar
Default Re: (jeffk182)
There are also little levels on them, so that should help. Be sure to have someone or something that weighs as much as you in the driver seat when you do it though. I neglected to do that.
Edit: You CAN use a screwdriver, but it's much slower. Just get a 10mm socket and do it that way. Much faster and easier.
Old Nov 27, 2004 | 08:59 PM
jeffk182's Avatar
Default Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">There are also little levels on them, so that should help. Be sure to have someone or something that weighs as much as you in the driver seat when you do it though. I neglected to do that. </TD></TR></TABLE>
Thanks for the tip
ajjct
21
Apr 27, 2013 09:41 AM
TheMoogly
Honda Civic (2001 - 2005)
11
May 13, 2007 11:25 AM
kikkoboyie
Feb 13, 2006 08:07 PM
DYRcivic
Aug 1, 2005 10:56 AM
jerknob
Mar 20, 2003 10:54 AM
