What all crosses over between civic, and crx?
Old Dec 30, 2001 | 06:02 AM
DragII's Avatar
25 Year Member
Default What all crosses over between civic, and crx?
Getting ready to grab some parts for my 89 Si hatch....just wondering if I can pull from crx's as well.
what x's over? from engine, to suspension, ect..
TIA
Old Dec 30, 2001 | 08:52 AM
AudioXtremes's Avatar
Default Re: What all crosses over between civic, and crx? (DragII)
most everything. just try and see. crx si - civic si = same car different butt.
Old Dec 30, 2001 | 08:59 AM
Krow's Avatar
Default Re: What all crosses over between civic, and crx? (AudioXtremes)
Yep I am headed down to the junkyard to see if I can find new seats for my si. I have been told that just about anything can be changed, but some stuff takes modification to make it fit.
Old Dec 30, 2001 | 03:54 PM
DR. ON POINT's Avatar
Banned
Default Re: What all crosses over between civic, and crx? (Krow)
2nd gen integra stuff fits.......90-93 integra
ur question isnt to clear...i dont undersatnd it
Old Dec 30, 2001 | 04:16 PM
DragII's Avatar
25 Year Member
cool....thanks! that's what I figured.....so which is the best route for 4wheel disks? use the crx rears, or the teg ones?
Old Dec 30, 2001 | 04:23 PM
JDM_DOHC_SiR's Avatar
New User
Either will be fine 90~93 teg or the CR-X ones will work you'll just need the brake cables from the CR-X.
Old Dec 30, 2001 | 04:24 PM
DragII's Avatar
25 Year Member
Default Re: What all crosses over between civic, and crx? (JDM_DOHC_SiR)
sweet...thanks much for the info
Old Dec 30, 2001 | 04:37 PM
BigBlockCRX's Avatar
New User
you can use the rear disc cables from a teg too..
get a crx dash and put it in your 89 civic.. makes it easier on the eyes..
Old Dec 31, 2001 | 01:37 AM
E-lude78's Avatar
Default Re: What all crosses over between civic, and crx? (DOHC DX)
If I install the 'teg front and rear brakes, which braided brake lines do I order, civic or 'teg? Is it a necessity to change the master cylinder too?
Old Dec 31, 2001 | 08:35 AM
DragII's Avatar
25 Year Member
Default Re: What all crosses over between civic, and crx? (Mista B-one-seven)
that's pretty nice...is it hard to put in that dash? or is it a bolt on affair?
Old Dec 31, 2001 | 09:25 AM
JohnnyM's Avatar
Hey DOHC DX. Like your rear brake swap. What kind of brake pads you using??
Old Dec 31, 2001 | 10:19 AM
E-AT_me's Avatar
Default Re: What all crosses over between civic, and crx? (JohnnyM)
oh no oh no!!! are the teg brakes the same as the EX?? if so, it WON'T WORK on the front!!! because, i tried this yesterday on my 1990 CRX Si. the rotors are just a little bit too thick along with the caliper mount, so you can mount the calipers to the knuckles because they are sandwiched between the knuckles and discs.. i had to find out the hard way....
Old Dec 31, 2001 | 12:59 PM
SiR Kid's Avatar
New User
Default Re: What all crosses over between civic, and crx? (Rexman)
I did that too Gotta have EX spindles for the integ brakes to work. I'm awaiting money to do this swap... someday, hopefully
Old Dec 31, 2001 | 08:35 PM
AV3's Avatar
AV3
I know the inside seat rails (closest to the hand brake) are not the same. The seats swapp just fine though as long as you use the CRX's rails.
Old Dec 31, 2001 | 09:54 PM
EVIL Hx Coupe's Avatar
Johnny do you have any more pics of your car??? If you do can I see them, I think I like your car alot just from looking at it in the rear.
Old Jan 1, 2002 | 09:03 AM
kefka's Avatar
Default Re: What all crosses over between civic, and crx? (Boost Pressure)
hey dohcdx that steering wheel looks like a prelude wheel...
Old Jan 1, 2002 | 11:45 AM
SiR Kid's Avatar
New User
DOHC DX, withthe integra rears did you use the Civic trailing arms or the Integs full system?
I used all integ parts and My backspacing seems to have been changed... You noticed anything?
Old Jan 2, 2002 | 08:32 AM
SiR Kid's Avatar
New User
WHen you say lower control arms... do you mean the rear lower control arms? I used EVERYTHING from the integra in the rear, except the springs and shocks... Just tore it out of the integ and bolted it into my car... Was I correct in doing this?
Old Jan 2, 2002 | 08:47 AM
JohnnyM's Avatar
Hey Boost Pressure..
here ya go... try this link http://www.geocities.com/CapitolHill/House/3020/
[Modified by JohnnyM, 5:47 PM 1/2/2002]
Old Jan 2, 2002 | 08:58 AM
New User
whoa wait a minute.. when you use the front teg knuckle for the bigger brake upgrade. you need to use the teg brake caliper too!..
if not, you will have problems..
I use 94+ teg knuckles with calipers and you will have to re-align your front end a little bit
its really easy, cheap and not a big deal to do.. plus you stop a lot quicker, great for you street racers out there
Old Jan 2, 2002 | 08:59 AM
WuShu's Avatar
New User
Finally, Antonio comes to the darkside, welcome homie.
Now you can join our club:
HB SQUAD
"We dont need no stinkin trunks"
yo dat madd skeety(*TM of dragII)
*had to add that, dont wana get sued you know!
Old Jan 2, 2002 | 10:59 AM
SiR Kid's Avatar
New User
Makes sense... dammit... more time and money down the tubes
78CITYTURBO
Classic Hondas
Dec 6, 2009 07:57 PM
sonic47
33
Dec 7, 2008 04:04 PM
SkRoMeEnIzANoNo
Aug 5, 2006 11:11 AM
RallySportCivic
21
Oct 21, 2002 03:07 PM
