uberdata datalogging cable soldering and installation
Old Nov 27, 2004 | 05:31 PM
pinche's Avatar
Default uberdata datalogging cable soldering and installation
hello i have a p28 ecu, ready for uberdata, the only thing i am lacking is how to solder in the data logging nokia usb cable. i have lots of wires on my cable i know i need to use the red, orange and ground. what are the red and orange tx,rx. please let me know. i have searched profoundly and found minimal actual installation instructions, maybe i am blind but please help, or show me to a page that can help. thanks
Old Dec 16, 2004 | 05:09 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: uberdata datalogging cable soldering and installation (pinche)
http://home.mn.rr.com/keebler6....html
Old Dec 19, 2004 | 06:21 PM
99lsvtecauto's Avatar
Default Re: uberdata datalogging cable soldering and installation (Built B16A)
go to this site http://www.ecimulti.org/uberdata/ for the soldering inside the ecu where it says cn2 u have to use the radioshack cable part number 170787 its 10 dollars cut off the end tap into wire brown, red and orange the rest u don't need cut them and tap them off.
On the ecu u solder wires from or run wires off and solder them to pin 1,2,4 u don't use 3 or 5
pin 1 is brown
pin 2 is red
pin 4 is orange double check keebler site for what 2 connect but these are the right pins 1,2, & 4
djnikko
Engine Management and Tuning
Dec 21, 2009 03:33 AM
Devo94ac
Mar 17, 2007 12:02 PM
JDMlyfestyle
37
Oct 16, 2005 08:42 AM
90crxsi88zc
Oct 6, 2005 05:04 PM
pinche
Nov 27, 2004 07:02 PM
