linkage
Old Nov 27, 2004 | 05:30 PM
dragaholic's Avatar
Default linkage
would the linkage with shifter off of a jdm 91 civic with a zc motor work on a usdm 87 integra with a 92 zc.
Old Nov 27, 2004 | 10:30 PM
sicsixone's Avatar
Default Re: linkage (dragaholic)
no the shift stabilizer rod brackets are different
Old Nov 28, 2004 | 04:32 AM
dragaholic's Avatar
Default Re: linkage (jonsswapshop)
care to explain how it is different. I may be able to modify it to work unless it is very different.
Old Nov 28, 2004 | 04:01 PM
dragaholic's Avatar
bump
Old Nov 29, 2004 | 06:27 AM
dragaholic's Avatar
hey jon,
is it that the rods will be to short or in the wrong position, because i have already altered the original teg rods to work with the zc motor.
Old Nov 29, 2004 | 10:22 PM
sicsixone's Avatar
yes you can cut the rod ends of and weld them on, swap them.if thats what you mean by alter.but it is not a direct fit.
Jan 6, 2018 05:43 AM
Seijuro Hiko
Jan 14, 2005 03:52 PM
Ronin Panda
May 29, 2003 06:33 AM
Ronin Panda
May 17, 2003 04:32 PM
