sagging door
drivers side door is sagging and rubs door sill and pillar upon closing ,i can lift up on door and it moves up where it probably should be. the hinges look ok and bolts are tight. the pins dont appear bent , what do i need to do to fix this? thanks
If you loosen the mounting bolts, you can move the door around a little bit to adjust the position. A helping hand is probably needed for that, those doors are a lot heavier than they feel on the car.
tha Big EZ
Dec 4, 2003 10:47 AM
