Is this a sign of a bad Clutch Master Cylinder???
Old Nov 27, 2004 | 04:36 PM
b00stedbyFastrax's Avatar
Default Is this a sign of a bad Clutch Master Cylinder???
run through all gears on the highway (cruise speed) and when is time to gear down from fifth to fourth or fifth to third etc, the gears would not go in. it also has this problem at a complete stop, at times no gear would go in. i normally have to press the clutch several times to get in gear. however it does go into all gears from 1st to 5th when I am running down the 1/4. i checked the reservoir and there seems to be no loss of fluid. checked inside the car and there was only a very small trace of clutch fluid. so is it the cmcyl?
Old Nov 27, 2004 | 11:20 PM
sicsixone's Avatar
Default Re: Is this a sign of a bad Clutch Master Cylinder??? (b00stedbyFastrax)
if you have a loss of fluid from the reservior than you have a leak some were.you can try to blead the system out and see if you have any air trapped in the system.if you do have air in the lines than you have a leak.if you do have a leak than change the master cylinder and the slave.it does sound like a hydraulics problem.
mouab18c1
Oct 21, 2009 10:07 PM
sipolt89
Dec 10, 2008 02:34 PM
Kyle244R948
Aug 7, 2008 10:30 AM
Tegraracer90
Mar 10, 2008 12:55 PM
BrokeAssAcura
Mar 4, 2004 08:26 AM
