Look what I got.....
Old Dec 30, 2001 | 01:19 AM
ThePunk's Avatar
Default Look what I got.....
GSRgrrl's ITR suspension conversion has arrived!
I have a few questions though...
(Please read: Anyone who doesn't OWN a ITR, or who hasn't done one of these conversions themself, please keep your comments to yourself. I did a search, and all I could find was a bunch of idiots saying "There are NO benifits to doing this conversion...all it is is a extra lugnut...")
Here's what we got: Front knuckle assemblies (Including rotor, caliper, spindle, and ABS sensor.) Rear trailing arm assemblies (Including rotor, caliper, trailing arm, upper control arm, ABS sensor, and parking brake cables.)
We are installing my set of goodridge SS brake lines (ITR spec).And are planning on using the factory GSR master cylinder, and springs/struts for now. Therefore, will we be able to use the GSR front and rear lower control arms instead of the ITR's? Also, down the road a bit, when more $$ comes available, can we switch to a ITR spec coilover setup, just by changing out the LCA's?
Of course, while everythings apart, 4 new rotors and pads are going in along with a poly bushing kit.
Any input/advice is appreciated!
Old Dec 30, 2001 | 04:49 AM
Zeus's Avatar
Default Re: Look what I got..... (ThePunk)
...only thing I have to add is that you will probably prefer to use the ITR master cylinder/booster before its done...
Old Dec 30, 2001 | 05:06 AM
1GreyTeg's Avatar
Get in touch with Rodney I'm sure he has some advice and can help you, he has a hybrid Civic/ITR conversion.
Let him know I sent ya he's a great guy.
A.
Old Dec 30, 2001 | 03:57 PM
ThePunk's Avatar
Default Re: Look what I got..... (1GreyTeg)
Anyone else?
Old Dec 30, 2001 | 04:02 PM
2k1TypeR0610's Avatar
New User
The proportioning valve is also important so that the right pressure is sent to the rear calipers.
Old Dec 30, 2001 | 04:06 PM
Spikey's Avatar
Default Re: Look what I got..... (2k1TypeR0610)
agreed!
the type r master cylinder/booster/proportioning valve make a huge difference
Old Dec 30, 2001 | 04:35 PM
Jimmy L's Avatar
Yes. The front is the same, only the rear shock mounts differently from a GSR.
Yes, and again you only need the rear LCAs which cost about $100.
I'm in the process of doing something similar to my hatchback. You should think about using the ITR rear sway bar as well.
Old Dec 30, 2001 | 04:53 PM
ThePunk's Avatar
Aren't the rear calipers the same between the GSR and the Type-r? I thought they were just mounted differently for the larger rotors?
Old Dec 30, 2001 | 04:55 PM
jeff652's Avatar
Wow the mis-information in this thread is impressive.
First off the GSR MC is the *exact* same part as the R one. Don't need to change that.
The GSR and Type R Prop valve are the same, again no need to change.
You will NOT need to change the E brake cables . . Thay are the same. This alone will save you 2+ hours.
The front GSR swaybar AND LCA's are IDENTICAL to the R ones, so there is no reason or benifit to changing them.
Use the Type R upper A arms, instead of the GSRs, as they are a fraction longer and will compensate for a lower ride height (as the R is lower from the factory).
You can swap on the 5 lug and still use the GSR LCA's, then when you get a suspension that needs the R LCA's throw them on then.
I know *I have done this*, heck I was the one that wrote the article on how to do this . . .
http://hybrid.honda-perf.org/tech/5lug.html
Email me if you have more questions . . .
Old Dec 30, 2001 | 05:02 PM
ThePunk's Avatar
Default Re: Look what I got..... (jeff652)
Thanks Jeff,
That's the kind of "Informed" info I am looking for.
Old Dec 30, 2001 | 06:35 PM
Mike K's Avatar
Jeff.. I think the upper A-arms are the same for GSR/ITR.
I may be wrong.. or YOU may be wrong.
I'll check the parts catalog tomorrow at work.
Oh, and Punk.. Jeff knows what he's talkin about. Dat **** bolts right on. Especially w/ the goodridge lines.. your girl will love the braking power over the GSR brakes.
Old Dec 30, 2001 | 06:57 PM
Ausmith's Avatar
Default Re: Look what I got..... (Mr. JDM)
The GSR and ITR Masters are both 1".
Old Dec 30, 2001 | 08:23 PM
jeff652's Avatar
Default Re: Look what I got..... (Mike K)
Yes Mike do check it out.
I've heard they're different from a few different people (hence my assumption), but I've never verified with part numbers. It'd be good to know 100% for sure . . .
Old Dec 30, 2001 | 08:33 PM
ThePunk's Avatar
I have the upper A-arms from the type-R, so when I do the swap I will take some measurements...I intend to FULLY document this entire process, so these questions will all have answers as well. (Much like Jeff's civic/5 lug how-to)
mofo951
Mar 7, 2009 03:36 PM
caiboR
Oct 13, 2008 12:03 PM
solid gsr
Nov 19, 2006 07:26 PM
ThePunk
Mar 7, 2002 03:50 PM
