97 ex, removing door panel? tips?
Old Nov 27, 2004 | 01:13 PM
xXx Justin xXx's Avatar
Default 97 ex, removing door panel? tips?
any tips needed to remove the passenger side door panel on a 97 ex accord coupe? or should it be straight forward like civics and integra's? thanks
girl at work rolled her window down, rolled it back up and the glass stayed at the bottom like the screws came off..... glass slides up and down track as smooth as silk.. said it didnt act binded up ever. just didnt come up one day. any other guesses?
Old Nov 27, 2004 | 01:40 PM
Lostcb7's Avatar
Default Re: 97 ex, removing door panel? tips? (red-DC2)
My drivers side window does this, I am also interested in how to fix it.
As for taking of the door panels, it's a few screws and some tabs and it comes right off.
Old Nov 27, 2004 | 02:35 PM
Default Re: 97 ex, removing door panel? tips? (Lostcb7)
cool. thanks
Old Nov 28, 2004 | 01:14 AM
tjohnson329's Avatar
what you ned o do is ake of the door. First you pull the black thing covering the mirror back. It will come off with a good pull. then you take out the screw by the door lever opener, might even be covered by a little sticker to hid it from sight. The next screw for the door is in the change collecter on the door (some call it the handle grip for closing the door) it is straight in the bottom. All you do is after unscrewing all of them you pull the door at the bottom and it will pop the clamps out of place and then lift it up but be carefull of the window wires still attached to it.
Old Nov 28, 2004 | 12:14 PM
Default Re: 97 ex, removing door panel? tips? (tjohnson329)
ok, thanks
gnarciv
Mar 20, 2008 03:14 PM
tom48
Oct 17, 2007 09:05 PM
nihkiru
Jun 10, 2007 01:33 AM
calicojones
Feb 22, 2006 09:14 AM
businessmanph
Oct 30, 2005 10:45 PM
