What is JL's Best?
Old Nov 27, 2004 | 12:03 PM
skrewdriver88's Avatar
Default What is JL's Best?
What in your opinion is the best 10 inch JL Subs for a 97 civic?
Old Nov 27, 2004 | 12:50 PM
swatdog's Avatar
if you get a w7, it may be a little too much bass for your tiny ciivc...
Old Nov 27, 2004 | 02:31 PM
Rollmodl's Avatar
Default Re: What is JL's Best? (skrewdriver88)
It would depend on how much wattage you plan on using. I would first decide on how much I would pay for an amp and how much wattage it be and then choose the sub from there. This way you using the full potential of you equipment. Its no use to buy a W7 if your amp will only be about 300 watts rms, you wont be able to get the full output from the sub. Remember all you have to do is to match your components. Personally I'm going with a single 12W3v2 using a JL 400 watt mono amp
http://www.jlaudio.com/subwoofers/RP_Chart.html
Old Nov 28, 2004 | 08:43 AM
lunchboxEF91's Avatar
dub 7
Old Nov 28, 2004 | 05:55 PM
rodimus's Avatar
Default Re: (swatdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swatdog &raquo;</TD></TR><TR><TD CLASS="quote">if you get a w7, it may be a little too much bass for your tiny ciivc...</TD></TR></TABLE>
HA!.
i had a 10W7 in my integra powered by a 500/1 jl monoblock amp.
it was great, but let's just say it could have been a little louder.
(it was ported to optimal specs, so it was at near max output)
but i guess everyone's different.
Old Nov 28, 2004 | 07:49 PM
EBP_SI's Avatar
Default Re: (EVOL)
what is the point of this thread, its pretty clear from their site that the W7 is the best driver they make. now asking which one suits your needs the best is a different question.
Old Nov 29, 2004 | 02:27 AM
rodimus's Avatar
Default Re: (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">what is the point of this thread, its pretty clear from their site that the W7 is the best driver they make. now asking which one suits your needs the best is a different question. </TD></TR></TABLE>
i.e. BUDGET.
Old Nov 29, 2004 | 08:36 AM
milton's Avatar
w6v2 would be ok for your civic
Old Nov 29, 2004 | 09:32 AM
CivicSiRracer69's Avatar
Default Re: (milton)
if you want bang.
JL 1000.1
13" JL W7
Old Nov 29, 2004 | 11:10 AM
ATF Kuk's Avatar
i have always been a fan of the old W0.
Old Nov 29, 2004 | 11:26 AM
rcurley55's Avatar
New User
Default Re: What is JL's Best? (ATF Kuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">i have always been a fan of the old W0. </TD></TR></TABLE>
I liked the w1 better....I still have a single 8W1 in my '55 and I have a buddy with a pair of 10W1's in a JL built bandpass box...for a bp, it sounded pretty darn good...at the time he ran it with a Punch 60ix
Old Nov 29, 2004 | 07:11 PM
ATF Kuk's Avatar
Default Re: What is JL's Best? (rcurley55)
i never had a chance to listen to a W1. i used to have 2 10" jl w0 in a jl box. it was great for a while. then i moved to a single 12"w0 with a custom box. was it was great for a first woofer experience.
now and then, i come across some customers with a w0 and w3. it reminds me of my first.
now i listen to the new jl's... just crap. W7 is nice though.
Old Nov 30, 2004 | 02:45 PM
The Alchemist...
Guest
Posts: n/a
Umm if I knew the amp specs and your goals I would be a lot more help. For something low power or with a cheap amp W0. If you want to shell out some money for an amp then you can move up in speakers. If you want something in the middle W3 is a good choice for you.
Old Nov 30, 2004 | 04:50 PM
Punkrocka436's Avatar
Default Re: What is JL's Best? (w-a-o)
SQ- 12w6v2
SPL- 12w7
Even the top techie at JL says the w6 sounds better than the w7
Old Nov 30, 2004 | 06:31 PM
b18bEG's Avatar
best for what?
Old Nov 30, 2004 | 10:38 PM
CarAudioPro's Avatar
Default Re: (b18bEG)
all depends on what your trying to do. i personally think the w3v2 is the best sounding sub that jl currently makes. w6's hit a lil harder and go deeper than the w3v2, but the w3v2 sounds all around better. and the w7 is a massive decent sounding spl sub. but the w3v2 still sounds the best. thats why you do like 3 or 4 of em, and then its on like donkey kong beeatch
Old Nov 30, 2004 | 10:43 PM
GSteg's Avatar
Default Re: What is JL's Best? (Punkrocka436)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Punkrocka436 &raquo;</TD></TR><TR><TD CLASS="quote">SQ- 12w6v2
SPL- 12w7
Even the top techie at JL says the w6 sounds better than the w7</TD></TR></TABLE>
which techie are you taking about?
one of the "techie" told me that the difference between the w6v2 and w7 is mainly output. the W7 has more output when driven to its limit.
And as far as actually sounding better, it shouldn't as JL said they basically share the same sonic characteristics.
though at higher volume, the w7 should be able to stay more linear than the w6v2 before inducing a bunch of distortion.
Old Dec 1, 2004 | 09:33 AM
snipermgr's Avatar
Put two jlw3's in a box with a single 6 inch port and that will sounds clean
Old Dec 3, 2004 | 06:43 AM
rodimus's Avatar
Default Re: What is JL's Best? (GSteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSteg &raquo;</TD></TR><TR><TD CLASS="quote">
though at higher volume, the w7 should be able to stay more linear than the w6v2 before inducing a bunch of distortion. </TD></TR></TABLE>
and per the JL website, W7 is their "SQL" sub.
my W7 was probably the best overall sub i've owned as far as SQ/SPL, excluding the fact that i got it at cost and it was still a lot of money for it.
Old Dec 4, 2004 | 02:58 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: What is JL's Best? (EVOL)
I'm a JL authorized dealer.
The W6v2's are perfect SQ subs with more than enough output for 90% of my customers.
For those willing to spend thousands of dollars on their bass... by all means... get the W7's with a multi-thousand watt amp. More profit for me.
The W7 runners are usually my H2, Denali, or Escalade folks with money to burn.
Two 12W7's and a couple thousand watt amp = $2000.00. That more than some of our cars.
All my installers love the W6's. More economical (well compared to the W7's) and awesome performance.
Old Dec 9, 2004 | 05:57 AM
madlion's Avatar
Default Re: (snipermgr)
tru that i had 2 10w3s with a fosgate 500 amp in a ported box back in the day and it pounded atleast 140sdecible
Old Dec 9, 2004 | 05:58 AM
madlion's Avatar
Default w7s blow
the 12w7 and 13w7 cant hit fast higher frequency bass notes without distorting
Old Dec 9, 2004 | 09:00 AM
Agent Daimon's Avatar
Default Re: w7s blow (madlion)
10w6 = amazing
Old Dec 9, 2004 | 10:54 AM
bossman032's Avatar
Default Re: w7s blow (Agent Daimon)
I had a w7 13.5.
That is a bad *** woofer.
Its hits so hard makes my ear bleed ok not bleed but u get the Idea.
It was run by the MTX amp. If you get the 12s are gay get the 13.5. If you wanna get the 12" look into Image Dynamics IDMAX those are badass they compare to the 13.5
I will be getting two for the civic
picture link.
http://pg.photos.yahoo.com/ph/...rc=ph
this was so heavy that I hook on my back for 1 week two people lifting it. Had 3 people when putting in the car two inside and one outside
Old Dec 9, 2004 | 12:35 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madlion &raquo;</TD></TR><TR><TD CLASS="quote">the 12w7 and 13w7 cant hit fast higher frequency bass notes without distorting</TD></TR></TABLE>
how high are you talking?
