B18A1+WRX stock turbo
Old Nov 27, 2004 | 07:39 AM
iguano's Avatar
Default B18A1+WRX stock turbo
hello guys, i want to know how will be a B18A1+WRX stok turbo??? wull be good??, if i have my internal stock will be a good inversment to put this turbo???
thanks
Old Nov 27, 2004 | 08:36 AM
dabig1's Avatar
Default Re: B18A1+WRX stock turbo (iguano)
i'm no expert and ihave no idea about wrx turbos but i'm guessing it will be a small turbo since you cant afford lag on a 4 wheel drive...but i dunno
Old Nov 27, 2004 | 08:37 AM
silly sohc's Avatar
TDO5L, with triangular flange? I had one of those turbos on a d16... too small for your setup (and mine), unless you are looking for instant spool and gasping for breath after 5k rpm. not worth it
Old Nov 27, 2004 | 02:13 PM
iguano's Avatar
Default Re: B18A1+WRX stock turbo (silly sohc)
i am not of usa so can you explain me that please??? i have that turbo in my hands because one friend of mine change his turbo and give this one for free, and it only have 3000 miles, its new, but its not a good setup for a b18a1????
thanks
Old Nov 27, 2004 | 03:59 PM
stealth89hatch's Avatar
the wrx uses a td04 turbo, not the td05. its made for the 2.0 liter of the wrx, but they sized the turbo small for wuick spool up and high rpm trailoff. it would probably work well but may lose boost high up there. the internal spring is set at around 13 psi.
Old Nov 28, 2004 | 10:50 AM
iguano's Avatar
Default Re: (stealth89hatch)
the turbo small for wuick spool up and high rpm trailoff. it would probably work well but may lose boost high up there. the internal spring is set at around 13 psi. [/QUOTE]
what means this.....????? i am new i this things of turbo!!!!
thanks
Old Apr 17, 2006 | 07:39 PM
b20vtechatch
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iguano &raquo;</TD></TR><TR><TD CLASS="quote">hello guys, i want to know how will be a B18A1+WRX stok turbo??? wull be good??, if i have my internal stock will be a good inversment to put this turbo???</TD></TR></TABLE>
i mildy built my b18a1 how much would i put down. 9.2cr
Guru Designs
Aug 19, 2005 10:28 AM
SFC
Aug 2, 2004 12:50 PM
4gvtec
Sep 19, 2002 07:08 AM
