NEED HELP! '00 SI harness ECU plugs!
Old Nov 27, 2004 | 07:26 AM
B18ek's Avatar
Default NEED HELP! '00 SI harness ECU plugs!
I just bought a 2000 civic SI engine harness OBD2b and there is only 3 plugs on the ECU side. There is supposed to be 4 right? 1 goes to the dash , 3 go to the ECU correct? Always 3 plugs that go to the ECU. Why is there ONLY 2 plugs that go to the ECU on this harness??? All thge 99-00 civic's I have seen had 3 plugs that go to the ECU,this harness does not look modified at all! Looks like a untouched engine wire harness from a 2000 Civic SI....
Old Nov 27, 2004 | 07:32 AM
locash's Avatar
Default Re: NEED HELP! '00 SI harness ECU plugs! (B18ek)
There are 3 ecu plugs in a 99-00 Civic Si. Two are on the engine harness, one is part of the cabin harness.
The 96-98 Civic's had all 3 on the engine harness. I hope you're not trying to use a 99-00 Civic Si harness in a 96-98 Civic..
Old Nov 27, 2004 | 07:35 AM
B18ek's Avatar
Default Re: NEED HELP! '00 SI harness ECU plugs! (locash)
Na, I am trying to put this in a 99 civic dx w/ a GSR swap!
Old Nov 27, 2004 | 07:39 AM
B18ek's Avatar
I have a 99 civic DX, 97 GSR motor, OBD2-1 conversion harness, 95 p72 GSR ECU. How am I supposed to do this? please help!! Will these parts work???
clark81
Sep 5, 2010 11:52 AM
hj2
21
Mar 3, 2009 03:56 PM
Jdmdctek
Jun 11, 2007 07:55 AM
fluxekhatch
Apr 13, 2006 06:33 PM
BOMBCRU
Apr 14, 2005 09:59 AM
