Bouncing idle on 91 hf
Old Nov 27, 2004 | 12:16 AM
cbrf-3's Avatar
Default Bouncing idle on 91 hf
my moms hf's idle is boucing up and down between 1000 and 1400 rpms. Its also boggin down around 1800 rpms, like a small flat spot and then it clears up around 2200. Ive cleaned the EAVC and still nothing, Plugs are alright to. thx in advance
Old Nov 27, 2004 | 01:05 AM
ukdm crx's Avatar
Default Re: Bouncing idle on 91 hf (cbrf-3)
welcome to the club mine does the same thing, the idle and the boging, I just deal with it cause it's done the idle thing before and it went away after a while. Really annoying though when your stopped at a stoplight.
Old Nov 27, 2004 | 08:24 AM
90hf's Avatar
Default Re: Bouncing idle on 91 hf (ukdm crx)
my 90 hf did that. i sprayed the throttle blade with carb cleaner. that fixed the idle problem. i slill have the flat spot. good luck
Old Nov 27, 2004 | 10:36 AM
90 Si Hatch's Avatar
Default Re: Bouncing idle on 91 hf (90hf)
when i had my 89 Std hatch it did the same thing till i got a new well used EAVC sensor!
Davesmit
Mar 24, 2019 11:27 AM
teamorange
Apr 25, 2005 10:23 AM
Jester88Si
Sep 9, 2004 03:59 AM
yomommassofat
May 21, 2003 10:01 PM
