Need some help before i start swap... Please help!
Hey im about to put in my b16. I have some questions before i start the swap. I want to have all the parts nesc. So please let me know if i need anything else besides what i list. Thanks.
Ok, im swapping a Gen 1 B16a into a 90 hatchback.
So far i have gathered that i need the following besides the motor:
Swap Motor Mounts
New Harness (Possibily a Plug and Play??)
91 Integra Throttle Cable
91 Integra Clutch Cable
91 Integra Axles
Shift Linkage
Do they make Plug and Play Harness's? If so, where can i find them?
Will the B16a shift linkage work in the hatch, or will i need one made for the swap?
Ok, now is there anything else i would need?
Swap Motor Mounts
91 Integra Axles
Shift Linkage
what model is your hatch dx, std,si? if its a dx then you need to do a dpfi->mpfi
hasport sell the wiring harness for bothe to swap and the dpfi->mpfi swap but you will also need a injector resistor box from a si or a crx si,hf and depending on what model you have you might need to switch out the hubs i also recomend a clutch, timing belt and water pump all good ins.
http://www.jdmshit.com Get there package for 325. Very good deal and the mounts are of a good quality
So all i will really need is the wiring?? Is there a site that sells a harness that i can just plug in and requires no wiring what so ever?
http://www.locashracing.com or you can pay 950$$$ and get the zdyne 1 wire vtec and its a full standalone system for pre obd cars
jdmnerd32
Dec 15, 2008 12:18 PM
scanz89
Jun 26, 2006 03:54 PM
damn_import_culture
Nov 19, 2004 10:07 AM
Dainbramage
Apr 25, 2004 08:06 AM
