Bad oil smell / white smoke burning off valve cover
My 92 Prelude Si is giving off a bad oil burning smell that permeates inside my car from the vents after driving it for a bit. I believe it's coming from the valve cover since I can see some thin white smoke floating off of it if I pop the hood after a drive. Its not excessive smoke, but enough to notice, and the smell is pretty damn bad from the inside. I recently had a valve adjustment done at a shop and talked to the mechanic there, and after taking the valve cover off, he said he didn't really see anything wrong. I had him use some hondabond to reseal on the valve cover before he put it back on too.
My valve cover looks like it may leaked oil on it after a drive, and I do burn a little bit of oil, but not too much.
What should I look at to be causing this problem?
Thanks
Thanks
It was actually leaking before I had my valve cover removed. However I can see traces of dried up oil around the edges of the valve cover, so I figure it must be leaking somewhere from there.
LSXFEIND
Apr 9, 2009 01:26 PM
Gummiej
Jul 18, 2006 12:09 AM
