rotors are fried
Old Dec 29, 2001 | 09:14 PM
FCdrifter's Avatar
New User
Default rotors are fried
after being abused at over 4 autox's and just hard street use my rotors are warped baaad. Should I just go ahead and resurface them or replace them with stock rotors or get a bigger size and how big can fit on the stock rims? The rotors just seem small for a 2700 pound fat ***
Old Dec 30, 2001 | 05:52 AM
1fastGSR's Avatar
New User
Default Re: rotors are fried (96greengsr)
if you autoX, I would invest on bigger rotors. Not sure how big you can go on stock 15" rims. You MIGHT need to upgrade to 16" rims.
Old Dec 30, 2001 | 06:47 AM
JCushing's Avatar
i emailed fastbrakes a little while ago andhe said you can get the rear larger caliper and the front brake kit and they will fit in stock 15's. the aem kit doesnt though i dont think. go to fastbrakes.com
Old Dec 30, 2001 | 07:05 AM
Max GSR's Avatar
It's not the size of the rotor that will keep them from warping. I've raced auto-x and HARD steet use on the same STOCK rotors for the last 3 years and they're in PERFECT condition. If yours are warped, then replace 'em. To keep 'em from warping again, you MUST cool them down properly when you race, or they'll warp again.
Couple of tips:
After you do an auto-x run, once you come to a final stop, don't let the car sit in the same position for more than 30 seconds. Each 30 seconds, roll the car forward about 6 inches. Do this for the next 5 minutes or so. The idea is to keep the pads from resting on the same place on the rotors for any length of time to allow the rotors (& pads) to cool down evenly.
I even do this after "spirited highway driving" and coming to a stop at an exit ramp for instance, or at a red light if I'm gonna have to wait for any length of time.
Another stoplight trick is to hold position with the parking brake instead of the footbrake... There's always less heat on the rear rotors than the front and the parking brake only engages the rears.
asianman139608
Jan 24, 2008 05:06 AM
illlyas
Aug 5, 2004 12:04 PM
vactor
Jun 26, 2003 02:24 PM
LSRydeR
Jan 7, 2003 08:21 AM
shamoo
25
May 31, 2002 09:54 PM
